    Results 1 to 9 of 9
      Sep 2013
      New Dakota Digital Fan Controller for The Camaro
      I just installed one of the new Dakota Digital PAC-2800BT fan controllers in the Camaro yesterday and love it. Tied it right into the Dakota Digital VHX control box and works like a charm. With this I can change on off temps on both fans and what mph to shut fans off from my iphone. I used to have to take to tuner to have these changed in the tune settings, but now I can tweak them as needed. Also has connection for fans when ac compressor is on.
      Very simple installation also.
      1967 Nova LS3 w/ 4l80 all TCI suspension with Ridetech coilovers, Detroit Speed mini tubbed with 18" Billet Specialties Prism wheels and 315 tire in rear, Wilwood Brakes, Quick Performance 9", custom interior, Fesler flush mount glass, Black Widow exhaust, vintage air and Kenwood bluetooth sound.
      Jacksonville, FL
      Good to know. Does it just connect like another BIM module? Any install pics?
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Sep 2016
      Bakersfield, CA
      I have the PAC-2750 fan controller and love it. My Holley EFI will soon be taking over its duties tho.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
      Oct 2015
      Western Mass
      I'm still trying to decide which fans to use, but I'm leaning towards adapting the Ford Contour/Mercury Cougar setup that was used in Super Chevy's article on a BBC (460 CI El Camino).
      Budget Dual Fans for Your BBC Chevy
      Can the Dakota Digital unit be used independently? And I have a Fitech unit sitting on the shelf (someday/maybe)... will it work with that?
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
      Sep 2016
      Bakersfield, CA
      I can be independent, just needs a temp sensor input. Don't know about Fitech, I'm a Holley user.
      Oct 2015
      Western Mass
      I just watched the video, it said that it can't control two (dual) 2-speed fans with speed A and speed B. It can control 2 (Dual) fans or a single 2-speed according to the video. The DD video didn't explain whether it would vary speeds... IOW run two fans at say 1000 rpm and ramp up to as high as 2000 rpm when needed.
      Sep 2016
      Bakersfield, CA
      Yeah, it's not a pwm controller. pretty much the limit is that each fan can have it's own on/off temp settings.
      Hildebran, NC
      Quote Originally Posted by OldTimer View Post
      Here is another discussion on standalone and pwm systems.
      https://www.pro-touring.com/threads/...wm+fan+control
      I have one (PAC-2800BT) getting installed in my car now.
