Vimes
07-17-2024, 07:03 AM
NOTE: Moved here from the HVAC section, realized I should have put it here.
Hopefully this won't upset anyone that I'm asking this, but I'm kinda stuck. This is on my beater, not my project. 2005 Dodge Dakota, 3.7L engine. The AC went out when the clutch stopped engaging on the compressor. When it would engage it worked great, but the clutch kept slipping more and more until it died, shortly after I bought it.
Anyway, I installed a new compressor, dryer, condenser and all three hoses. The orifice was replaced as it is a nonremovable part of the liquid line. I didn't flush the evaporator since the problem wasn't a clutch failure and not a compressor failure. Vacuumed it down, charged it up, and it showed decent pressure although a little on the low side for R134a. Think it was around 40ish on the low and 200 on the high, at 1500RPM. And, it blew icy cold air.
Now for the problem - The compressor doesn't cycle. It runs constantly. Also, the system is supposed to take 29oz, but I stopped at 41oz, or an extra can, measured on a precision scale before and after adding. The extra can was put in due to the clutch wasn't cycling and the pressure on both the high and low sides wasn't coming up. On past jobs, the compressor would run nonstop while adding, then the clutch would start cycling when the coolant got close to the correct amount. It started blowing R134a out the back of the compressor when I'd rev the engine. Sounds like an angry cat, sprays a fine mist. Am I looking at a bad new compressor or is there something I might have missed here? Possible bad high pressure switch? I know enough about how the AC system works that I've been able to repair them including full replacements over the years but this is the first time I've experienced a failure with new parts and I don't want to throw more parts at it without knowing what I might have screwed up. Thanks.
