- ac drain line routing (0 replies)
- changing a/c pulleys (11 replies)
- HVAC Bulkhead Routing (8 replies)
- A/C delete, anyone ever use this product? (3 replies)
- AC line crimping (11 replies)
- looking for a compact AC compressor (17 replies)
- overheating!!!! HELP!!!! (23 replies)
- runnnig a/c, heater lines (11 replies)
- Vintage air frontrunner price and/or opinions (4 replies)
- VA install pics (0 replies)
- A/C lines (4 replies)
- got my va kit today (4 replies)
- Need an Vintage Air vendor in LA area that's reputable and reasonably priced (6 replies)
- Vintage Air gen 2 work with Ls1 (1 replies)
- Cheap Heater Choice? Vintage Air? (7 replies)
- Vintage Air Compressor Will not come on (38 replies)
- Pics of subframe cut out for A/C comp. (5 replies)
- where do i get these parts? (2 replies)
- Vintage Air/Factory Questions (2 replies)
- Heater core install questions (2 replies)
- Lots of A/C Components... What will work? (1 replies)
- Vintage Air Dealer (8 replies)
- Vintage air Install (11 replies)
- Will Vintage air gen IV work with MSD box? (6 replies)
- Gen IV vinatge air/cooling fan question (3 replies)
- Staggered 9-inch fans (0 replies)
- EPA presses for fast switch to A/C refrigerant R-1234yf (14 replies)
- Aftermarket OR Factory Air (29 replies)
- Vintage Air shipping (5 replies)
- Vintage Air experts -- question about the Gen IV (24 replies)
- Compressor locks up (6 replies)
- Getting Rid of Rear Hood Vents? (3 replies)
- Are V/A Gen IV mock up blocks vehicle specific? (2 replies)
- melting heater core fittings (21 replies)
- CSR smallblock waterpump (3 replies)
- Frank- VA Bulkhead Question (7 replies)
- OE replacement for 396 auto? (3 replies)
- Need help on Vintage Air ordering (2 replies)
- VA Gen IV install in a 71 Nova (8 replies)
- Aftermarket A/C for 2nd Gen Firebird (11 replies)
- VA or Classic Custom Air (20 replies)
- A/C adapter fitting (11 replies)
- 69 Camaro Heater Control (2 replies)
- Heater question of '68 Camaro (1 replies)
- waterpump question (1 replies)
- VA Gen II install questions (2 replies)
- A/C heater core question (0 replies)
- Vintage Air interior clearance (10 replies)
- A/c orifice tube location (2 replies)
- Is air conditioning a must? (45 replies)
- Vintage Air/Firewall Questions (18 replies)
- Fan run keeps running (8 replies)
- 69 impala (1 replies)
- LS1 Swap in 68 cam. Is 00' AC setup junk or useful (5 replies)
- Sanden conevrsion (5 replies)
- Aeroquip EZ Clip Air Conditioning (2 replies)
- Anyone running a Gen-IV system in a '68 Camaro? Dimension needed (2 replies)
- Heater blower motor doesnt turn on, where to start? (7 replies)
- Hardcoat (black) Vintage air pics needed (2 replies)
- Heat/ AC Bulkhead Which One? (16 replies)
- electric a/c compressor (19 replies)
- Repairing stock AC boxes (4 replies)
- Aftermarket AC for 72 Nova that came withAC? (6 replies)
- Classic Auto Air Mustang kit ?'s (8 replies)
- A/C Vents (0 replies)
- 69 Camaro A/C Removal (3 replies)
- 68 Camaro factory AC VA question (9 replies)
- Where to start?? (0 replies)
- Vintage Air LS1 bracket (5 replies)
- Need some ideas on hose routing and cleanup for A/C. (0 replies)
- where can i have custom ac lines made? (6 replies)
- Adding a vent (0 replies)
- A-Body Radiator Support/Cover - any aftermaket Aluminum or SS? (1 replies)
- heater options (30 replies)
- vintage air w/ custom bulkhead (2 replies)
- Using stock A/C system with 69 FB LS1 conversion (9 replies)
- German Fog Machine (5 replies)
- what AC kit is this? (4 replies)
- Looking for SBF serpentine pulley system (6 replies)
- A/C theory question (12 replies)
- Slipping A/C clutch (29 replies)
- If A/C not cold enough. (6 replies)
- Vintage air gen IV and factory kick panel vents (6 replies)
- Fords w/A/C (0 replies)
- 70 chevelle A/C (1 replies)
- Complete Factory A/C parts available? (3 replies)
- 1967/8 Camaro Vintage Air Gen 4 install pictures (6 replies)
- which A/C unit? (14 replies)
- Do I or don't I?? HELP!!!! (5 replies)
- I want air on my 58 Nomad (5 replies)
- 67 firebird A/c heating (2 replies)
- 71 camaro A/c controls (2 replies)
- Compressor/rad hose (1 replies)
- A/C compressor on the passenger or driver side? (4 replies)
- RPM drops when turning A/C on (6 replies)
- Convert the head unit. (3 replies)
- 1st gen Camaro AC (0 replies)
- A/c And Heater Controls (0 replies)
- AC in a 68 Charger (0 replies)
- Want Ac In My 71 Ls1 (1 replies)
- Going with A/C finally Need some help (3 replies)
- VA heater control valve placement (2 replies)
- A few facts about AC (4 replies)
- Heater House Options ? (3 replies)
- Lt1 and vintage air (7 replies)
- a/c recommendation (2 replies)
- HVAC case underhood - WTH is this? (5 replies)
- R4 compressor or Sanden? (1 replies)
- Heater core (5 replies)
- Now taking orders for Vintage Air Camaro Gen IV systems (137 replies)
- Rebuild or replace? (16 replies)
- Vintage air in a Mopar (9 replies)
- classic auto air install question (16 replies)
- 2nd gen with ls1 a/c questions (10 replies)
- AC in a Olds?? (8 replies)
- Rear Defrost??? (8 replies)
- where can I get compreesor clutch for this setup?? (7 replies)
- Classic Auto Air / 2nd gen camaro (3 replies)
- Nova headache (4 replies)
- Gen3 compressor clutch options (0 replies)
- Heater hose fitting question (0 replies)
- Vintage Air (4 replies)
- AC vents(really cheap material)!! (7 replies)
- 76 Corvette - switch from A/C to heater only (19 replies)
- AC bracket question...PLEASE! (3 replies)
- 71 Blazer heater core R&R (7 replies)
- Second Gen Camaro AC System (10 replies)
- where to get 72 camaro AC vents? (7 replies)
- Crimping A/C hose ends? (9 replies)
- Vintage Air Installation (11 replies)
- 68 Camaro Sure Fit A/C Kit (3 replies)
- Heater Core Change out (2 replies)
- Old A.C. restoration (1 replies)
- Heater core gasket placement (2 replies)
- 68 Firebird with Factory AC to Vintage Air (7 replies)
- Moving the Accumulator on a 79 Z28 (0 replies)
- A/C compressor mount for BBC with electric water pump??? (0 replies)
- Does anyone make a?? (1 replies)
- My air does not work. Pretty broad statement, but I need help (1 replies)
- Clutch slipping problem (3 replies)
- heating & airconditioning (0 replies)
- ac brackets (0 replies)
- Want a smooth firewall but need heat and defrost, Options? (8 replies)
- Capillary tube? (2 replies)
- which refrigerant? (13 replies)
- AC for a '68 Camaro (3 replies)
- Vintage Air question too (1 replies)
- Center Dash Vent?? (2 replies)
- Vintage Air install help! (6 replies)
- Vintage Air in a Non-Air Car - Value? (1 replies)
- ac fitting availability (1 replies)
- Does your a/c really work? (47 replies)
- 68 Camaro heater box (3 replies)
- LS1/LS2 heater connections (1 replies)
- How much should I remove? (2 replies)
- AC compressor mounting position (1 replies)
- 69 Camaro with AC (need a source for cables) (0 replies)
- Need a vintage air kit -compressor for 68 Camaro (4 replies)
- Anyone Fabbed up a Block Off set for the Heater Box assembly? (10 replies)
- What compressor with LS1 and Vintage Air (23 replies)
- R12 private purchase. (27 replies)
- Ac (2 replies)
- Anyone Need an AC System? Vintage Air (12 replies)
- Doc's Blocks (0 replies)
- Anyone get hold of CAA (8 replies)
- Big block blower housing on small block car (5 replies)
- Vintage Air users with automatic trans coolers installed (4 replies)
- Gen 2 Vintage Air in 1st gen (9 replies)
- ac delete walkthrough? (2 replies)
- 69 camaro compressor location (2 replies)
- Ditch the a/c? (8 replies)
- an 10 adapter in water pump for heating? (3 replies)
- Heater & A/C Controls (1 replies)
- Installing Vintage Air Gen 2 in 67 Camaro (2 replies)
- 4th Gen Dash & AC (13 replies)
- Drier Location (3 replies)
- stock 69 camaro a/c to lt1 compressor (1 replies)
- Vintage Air (3 replies)
- When to run the ducts? (1 replies)
- How to connect AN lines to heatercore? (11 replies)
- AC Delete Box Resistor placement, 69 Camaro (6 replies)
- Vintage air condenser! (3 replies)
- Hidden AC Hoses (16 replies)
- 55-57 Chevy AC KIT (4 replies)
- Vintage Air Evaporator Case Mounting (5 replies)
- Just wondering? (5 replies)
- A/C lines (3 replies)
- Sure Fit to Gen II and bulkhead/lines questions. (0 replies)
- will a '68 Camaro heater box fit a '71 Malibu (5 replies)
- How do I, AC to non AC in a 73 Camaro (0 replies)
- Removing 73 Camaro heater/evaporator box (16 replies)
- Vintage Air problems (2 replies)
- Anybody got wiring diagrams for 98-02 Camaro AC? (4 replies)
- Digital Air Condition Guage (0 replies)
- Anyone convert their factory controls... (2 replies)
- How well does the sure fit system cool? (3 replies)
- Front runner/March Perf/Billet Spec (13 replies)
- Frontrunner questions. (8 replies)
- GM Factory AC (4 replies)
- Vintage Air A/C - defrost vents (4 replies)
- Vintage Air Question (1 replies)
- Classic (1 replies)
- A/C compressor noise? (11 replies)
- 1st Gen AC with LS1 (14 replies)
- VA Hose Length (0 replies)
- Vintage Air Frontrunner installed. (21 replies)
- Best choice? (0 replies)
- R4 Compressor brackets for Gen1 sb? (2 replies)
- A/C compressor (1 replies)
- Need contact info For American Graffiti (2 replies)
- what is the new origional a/c stuff worth (2 replies)
- Vintage Air - Drain? (1 replies)
- Vintage Air, Hot Rod Air vs. Factory Air (10 replies)
- Vintage Air Group Deal! (0 replies)
- pic of factory ac car with vintage air ? (13 replies)
- need heater help (8 replies)
- A/C charge ports (2 replies)
- Vintage air install - crimping lines (1 replies)
- Vintage Air Alternatives (26 replies)
- A?C problems after rebuild (1 replies)
- Dumb Vintage Air Sure Fit questions. (6 replies)
- Frontrunner (5 replies)
- Factory A/C to Vintage system? (5 replies)
- Where the heck is the plug for the heater fan? (3 replies)
- heater box instal (8 replies)
- pictures of where to mount the bulk head? (2 replies)
- 1st gen. Vintage Air install... (4 replies)
- Vintage Air Install Pics WANTED (1 replies)
- 68 Camaro AC removal (4 replies)
- Vintage Air on a 2nd Gen Camaro? (24 replies)
- Anyone planning on buying a Vintage Air Frontrunner? (0 replies)
- Should I install Vintage Air before paint? (1 replies)
- LT1 & Vintage Air. Compressor? (21 replies)
- Billet Specialties Tru Trac Serpentine Belt Accessory Systems (29 replies)
- Thoughts on Vintage air systems (3 replies)
