View Full Version : Engine Miscellaneous
Pages :
1
2]
3
4
5
6
7
8
9
10
11
12
13
14
- Using oil (2 replies)
- Bad intake valve? (6 replies)
- new cam installation, call people that made your cam to find valve adjustment spec (0 replies)
- Victor Intakes on Clearance, over $400 off! (0 replies)
- West Coast Engines 383 (7 replies)
- Ls3 Evap canister purge solenoid valve delete (1 replies)
- Engine Sealing (0 replies)
- Oxidation on Aluminum parts (7 replies)
- Rebuilt engine sat unused for 11 years - What should I do before using? (7 replies)
- Can anyone help me identify these SBC Heads????? (0 replies)
- Car won't start - suggestions please...? (1 replies)
- Opinions please (5 replies)
- comp cam xr282hr-10 lsa is 110 230/236 duration lift=510/520" mine will be a 108 lsa (4 replies)
- Bearing Spacers (5 replies)
- SBC compression limit (13 replies)
- Lokar gas pedal sticking (2 replies)
- Vacuum at max rpm question - EFI setup (25 replies)
- LS3 air intake breather options - 69 Camaro (11 replies)
- LS 2 bottum end (1 replies)
- Pontiac 400 Budget Build Help (15 replies)
- wet sump oil pan mods? (9 replies)
- Crankcase ventilation (15 replies)
- Bowtie Block Issue (6 replies)
- Oil pan needs (0 replies)
- Gold Canton parts (3 replies)
- What's it called (4 replies)
- Question on plugging the oil level sender (0 replies)
- Best Price on AFR heads? (0 replies)
- 2" inch drop base or greater for Holley carb needed (6 replies)
- Head bolt threads (9 replies)
- 2004 GTO LS-1 engine question, what is this line for ? (3 replies)
- Serpentine conversion question (18 replies)
- GM type 2 pumps? (0 replies)
- Holley Hi Ram (1 replies)
- Possible Best new air oil separator on the market (10 replies)
- exaggerated big bore short stroke engine? for street car (4 replies)
- Oil from breathers (21 replies)
- DSE Pontiac engine mounts (10 replies)
- Stupid Noob Question... (1 replies)
- 243 (LS6) vs LS3 heads - autocross (2 replies)
- Over revving 350 ramjet (1 replies)
- lm7 5.3 cost? (2 replies)
- learned the importance of checking plug wires (0 replies)
- learned the importance of check resistance in plug wires (0 replies)
- Lq4 coil covers?? (2 replies)
- Top End build help (10 replies)
- Straight or angle plug heads (5 replies)
- approximate torque and horse power (6 replies)
- Pontiac 400 build hp/tq information (8 replies)
- Holly LS1 Mid Rise Intake Question-69 Camaro Hood Clearance (0 replies)
- BB to SB Motor Mount ? (3 replies)
- 383 build (2 replies)
- floatless fuel sender (1 replies)
- Fuel line routing questions (24 replies)
- 400-430hp recipe SBC (16 replies)
- EFI fuel tanks (8 replies)
- Camshaft help (6 replies)
- Gen 2 Viper Engine Help (10 replies)
- 355 SBC Oil Pressure Issues (4 replies)
- Fast Burn Heads spring seats (0 replies)
- LS or Coyote in a '67 mustang Restomod - which is best ? (14 replies)
- FAST tranny kickdown bracket (1 replies)
- Pontiac 400 Rebuild......Worth it? (8 replies)
- Road Race Style Wet-Sump Oil Pan with Oil Level Sensor (1 replies)
- Mopar 340 or 426 (4 replies)
- drivability with a high ram or sheet metal intake on ls1 (8 replies)
- engine rpm (14 replies)
- air leaking past ex. valve while changing valve spring!!!!!!! (3 replies)
- BIG block been sitting. what to do, restoration process (8 replies)
- Miata just died going down the road (0 replies)
- Miata just died (11 replies)
- nitrous (9 replies)
- Removing dents in header tubes? (10 replies)
- Ceramic Coating (5 replies)
- 1964 Fairlane Mustang II Front Suspension 351W Swap Oil Pan (2 replies)
- Searching for Oil Pans... (1 replies)
- help , trying to get motor started (5 replies)
- Olds Guys...show us your Pulleys... (3 replies)
- Pinion Angle (2 replies)
- Oil Catch Can Question.. (11 replies)
- 6500 RPM 327, Hyper or Forged pistons? (4 replies)
- Who's still running a SBC ? (64 replies)
- Well, that was unexpected: engine/trans weights (3 replies)
- dropped a valve (2 replies)
- Engine buzz/vibration 2800 to 3200 rpm (11 replies)
- spark plug and gap (2 replies)
- oil pan ? (6 replies)
- Dry sump oil system on c4 corvettes (2 replies)
- Anyone have a CAD or similar drawing for a BBC Crank pulley? (2 replies)
- Puff of Smoke.. (4 replies)
- 383 damper bad? (5 replies)
- Low Fuel Pressure Help!! (4 replies)
- Help me with my budget 400 sbc build (0 replies)
- Help my C10 is killing me (8 replies)
- Frontrunner SBC power steering pump/ pulley (1 replies)
- I need help on BBC oil pressure (2 replies)
- 305 14014416 heads (1 replies)
- How do you turn a sbc counterclockwise? (12 replies)
- alternator bracket (6 replies)
- Head flow for autocross (6 replies)
- Question about fuel cell in Autocross/Road Race (10 replies)
- engine noise (1 replies)
- help 454 .070 bored (2 replies)
- LS3 Cam (2 replies)
- detriot speed motor mounts (0 replies)
- to go bbc or sbc? (12 replies)
- Hummer H3 Air filter (0 replies)
- driving me crazy.... (10 replies)
- Dyno (0 replies)
- does any one have a vapor lock solution ? (11 replies)
- Hot gasoline won't run (9 replies)
- Confused on crankcase pressure/venting (9 replies)
- High Compression/ Boost on the street... (9 replies)
- Adjustable tension pulley (0 replies)
- 572 engine accessories. (0 replies)
- What oil do most of you guys (and gals) use? (19 replies)
- Engine Compartment (0 replies)
- Fuel tank sending unit (3 replies)
- New ls3 crate engine warranty/ block cracked... Feedback (21 replies)
- Engine Advice Needed (2 replies)
- 318 build help (2 replies)
- Edelbrock Perform RPM intake and stock '67 Firebird hood. . .clearance/interference?? (0 replies)
- Bbc questions (13 replies)
- Hydro dipped manifold (2 replies)
- Lost Power Steering Assist (6 replies)
- 67 Pontiac lemans (8 replies)
- anyone run locked out timing on a BBC or SBC (9 replies)
- Engine Swap (2 replies)
- The Best Restomod Engine (10 replies)
- Need help with engine direction. (3 replies)
- Interesting Horsepower (10 replies)
- 8 into 1 header (15 replies)
- Rocker ratio changes duration? (3 replies)
- Braided lines and fittings (6 replies)
- 8100 496 with supercharger? (0 replies)
- Problems with Comp rockers on AFR 185 heads. (11 replies)
- Vaccuum lines 86 Monte Carlo SS (4 replies)
- Screw in valvecover baffles (3 replies)
- Driveline/Flywheel Set Up (3 replies)
- just found a leaky valve seal on my motor (0 replies)
- 351w Positve Valve Seal issue (0 replies)
- I need lifters!!! (5 replies)
- Fresh rebuild on SBC and the rear main is leaking (7 replies)
- Where to get braided power steering lines? (11 replies)
- How to find TDC on BBC (6 replies)
- L46 SBC....am I nuts? (23 replies)
- GM 427 BB - tall vs short deck? (2 replies)
- LS1 Ram Air Intake Manifold (7 replies)
- 1970 GTO 400 Build (10 replies)
- Worn Valve Spring Shims? (1 replies)
- Need a tuner in the Houston/Cypress, Texas area (0 replies)
- Valve Stem Seals, Which Brand? (2 replies)
- Motor ID (0 replies)
- AN Fittings (14 replies)
- Motor mounts - Anyone running one solid and one polymer? (11 replies)
- First it wouldn't Idle, now it won't run off idle! (4 replies)
- Looking for tuner in Orange County, CA (6 replies)
- Front Accesory Drive SBC whats good? (6 replies)
- Weird engine noise (5 replies)
- spark plug wire looms (1 replies)
- OBD1 Questions?????? (9 replies)
- Engine displacement measurements??? (6 replies)
- serpentine belt system (4 replies)
- Best head for a BBC... (5 replies)
- Experience with Marine sbc efi ntakes? (0 replies)
- Beginner looking for info on good cylinder heads SBF (0 replies)
- 396 lost oil pressure....need big help! (5 replies)
- Repairing threads on flywheel side of crankshaft, possible? (2 replies)
- LS intakes adapted to wenzler olds heads... (2 replies)
- LS MAP sensor (1 replies)
- PCV configuration (0 replies)
- 427 tall deck help (7 replies)
- Vacuum pump for crankcase ventilation (0 replies)
- Cruising with a solid roller cam (11 replies)
- BBC 402 good deal? (4 replies)
- Crankcase ventilation (28 replies)
- motor mounts on 77 z28 (1 replies)
- Stroked LT1 (3 replies)
- If you want something done right, do it yourself... (11 replies)
- Short Stroke BBC 477 Dyno Results - 2014 Engine Masters Challenge Motor (1 replies)
- burning plug's (0 replies)
- LS3 416 cam specs???? (2 replies)
- Would this cam cause my lack of vacuum?? (12 replies)
- Build up 302DZ or LS3? (11 replies)
- Motor opinion (1 replies)
- engine issues... (0 replies)
- DSE subframe and SBC (6 replies)
- 396 problem? (0 replies)
- Help with LS harmonic balancer install with motor in car (10 replies)
- Well I saw a guy running an LT style hub and balancer on earlier engine (5 replies)
- Head recommendations mild BBC (7 replies)
- Engine building philosophy. rocker or cam (6 replies)
- Jet-Hot Headers (0 replies)
- Harmonic balancer issue (5 replies)
- Scorpion Endurance Series Rockers (2 replies)
- keep blowing head gaskets, next step (8 replies)
- oil pressure low on small block rebuild (1 replies)
- SBO timing cover crank seal runout tolerance (3 replies)
- LS engine problem (9 replies)
- LS lift plate dimensions (template) (0 replies)
- 5.7 v/s 5.3 (11 replies)
- broken push rod (5 replies)
- Ls 1 (12 replies)
- breather and pcv question (3 replies)
- pontiac 400 compression test (5 replies)
- gmpp hot cam (1 replies)
- I need help! Too much presure in my block! AJs1luv (5 replies)
- 351 Windsor Issues Part 2 (4 replies)
- Changing cam on old style 350 how far does the oil pan have to drop to get cover off? (5 replies)
- 351 Windsor Issues (2 replies)
- Different intake styles (0 replies)
- looking for fabrication ideas (4 replies)
- LS6 intake on 383 stroker (8 replies)
- 509 rotating assembly (5 replies)
- AFR guideplates (0 replies)
- oil consumption??turbo pcv setup (6 replies)
- Solid vs Poly Motor Mounts (18 replies)
- How to achieve 900-1k hp? (11 replies)
- Trying to figure out what my BBC 402 is worth!! (1 replies)
- Is my hp/tq outputs correct? (3 replies)
- Helpneeded! Valvetrain ticking in SBC (3 replies)
- could anyone give me an estimation? (8 replies)
- No Breather (2 replies)
- Coolant Temp Sensor Location (1 replies)
- SR20 swap? (28 replies)
- Motor and mid plate question (2 replies)
- Intake 12496822 opinions.. Always looking for more HP! (4 replies)
- Mystery Part (2 replies)
- I need help!! - Engine Mounts, 2nd Gen (2 replies)
- front belt drive (0 replies)
- Leaking head gasket (1 replies)
- Basic SBC engine build help (5 replies)
- 454 Street performance combination request (0 replies)
- 305 Vortec SBC build (0 replies)
- Is this a good deal for a LS1 T-56 combo? (5 replies)
- Roller cam fuel pump rod????? (5 replies)
- motor planning, what to expect? (solo) (8 replies)
- 468 BBC or LQ9 conflict (8 replies)
- How to keep my Aluminum Block looking new ? (5 replies)
- GM Showroom Stock Cam (2 replies)
- New Intake manifold search (3 replies)
- zz4 fast Burn 385 by pace (9 replies)
- 427 seized up (6 replies)
- Starter questions... (3 replies)
- Valve Cover Problem (1 replies)
- first motor build (0 replies)
- Broken piston, CRAP! (4 replies)
- What Camshaft (6 replies)
- Harmonic Balancer suggestions needed (24 replies)
- Are AN hoses interchangeable? Also ID a fitting (5 replies)
