View Full Version : Pontiac 400 build hp/tq information
Brody
05-24-2016, 10:46 PM
Hello I'm new here and looking to get an idea on what I can expect from my Pontiac 400 combo. Is there a fresh thread any of you Pontiac guys can direct me to, or should I just describe my combo here?
brody
another69
05-25-2016, 06:44 PM
Pontiacs are interesting motors. I just wrapped up a 350 which was my 1st Pontiac motor. If you are looking for info, Butler is a good source. What are your plans with it?
71Blackbird
05-25-2016, 09:07 PM
There are some guys and info on Pontiac Street Performance that really know their stuff. They helped me a ton. I am just completing my 71 formula. Torque is not an issue with Pontiacs they have a ton of it.
Brody
05-26-2016, 03:53 AM
The 400 is in a 66 Lemans and is a blast to drive. kept the crank and rods but everything else has been upgraded. I was planning on having the car put on a dyno just to see what the numbers are at the wheels and wanted to know ahead of time what to expect. Also trying to decide on an exhaust system for it 2.5" or 3" depending what hp/tq I end up with. Leaning to the 2.5 exhaust because it's my understanding that anything under 500hp and your actually losing torque with too big of an exhaust. Pretty sure I'm not quite there.
Butler quoted me for a build a while back and they were pretty good but I decided to go local, save a little money on shipping. I forgot about Pontiac Street Performance I'll have to dig through their threads to see if anyone has a simular build.
Interceptor5588
05-26-2016, 05:11 AM
400 hp is pretty common with good heads and cam. Need to get radical or stroke it to go much beyond.
http://forums.maxperformanceinc.com/forums/
salesguy01
05-27-2016, 05:17 PM
Yes That is a Great Resource! Pontiacs can get Expensive Fast!!! I could have bought a crate LSA and trans combo for the money I have in my Flat Tappet 467 Pontiac build....
BUT when opening the hood at the car show its priceless to get the compliments on Pontiac powah!
Brody
05-27-2016, 11:10 PM
400 hp seems to be the norm for a decent Pontiac 400 so I'm guessing somewhere around 450 to 485 for torque? Knowing what I know now I wish I would of went for aftermarket rods. I know the machine shop did a good job inspecting and reconditioning mine but... With my combo I'm thinking probably keep it around 5500 rpm for red line?
73' Pontiac 400 block 60 over
stock crank
stock rods
Sealed Power forged pistons
Comp Cam # 51- 423-9 hydraulic roller
(276/282) (224/[email protected])
Roller rockers
9.5/1 compression
Edlebrock performer heads
87cc chamber 215cc intake 175cc exhaust. 211/166 intake/exhaust valve diameter.
Edlebrock performer RPM intake
Sean Murphy Induction stage 2 800 cfm quadrajet
DUI HEI distributer 22 at 3000 rpm
Art Carr 200 4r trans with 2200-2400 stall converter
3:55 gears
jtwoods4
05-31-2016, 06:40 PM
I road race a 1970 Trans Am. I run a Pontiac 400 (406). At the crank it was dynoed at 480 on hp and tq. This is achieved with a great port job on eddlebrock aluminum heads. Long Chevy big block rods. All forged rotating assembly. I also have dyno sheet and detailed cam specs. Contact me with any questions. I also have a 461 stroker pushing 550 hp/tq. I know Pontiacs. Message or email me. My YouTube channel is jtwoods41978 you can see engine details and road race videos somewhere in my videos.
F-Body International
08-13-2016, 09:16 AM
What year block is the 400? This can determine the limit of where you want to take the power. Many stay away from the mid 70's blocks. The only "good" late blocks known are the 78-79 W72 400 engine blocks. These are also known as the 988 blocks.
If it's a Trans Am, I think the best setup right now is getting a Torker II intake, FiTech TBI, MSD ignition and Pro-Touring F-Body drop base on there. This will surely help for power production.
