View Full Version : comp cam xr282hr-10 lsa is 110 230/236 duration lift=510/520" mine will be a 108 lsa
garvir
01-31-2017, 06:31 PM
i ordered this cam from comp, but i had them grind it with a 108 lsa. the 110 lsa was a good cam, but to tame. i like a lot of nasty sound. i use this car for road racing, run between 3000 and 6000 rpm, need that torque to get off the corners. the car is a 88 monte carlo, weighs 3000 lbs, 295/50r15 tires in rear, 235/60 on the front, very well balance, no push.
super chevy ran this cam on a 350 sbc with fast burn heads (that is what i have) here is dyno pull. this motor is just like mine. the only thing super chevy did differant was to advance (brings more power down low) the cam 2 degrees, and they picked up 6 to 12 hp and tq in the whole rpm range136667, which is what i am doing with a 108 lsa, but i will run my cam straight up. super chevy did a dyno run with fastburn heads sbc, this cam but a 110LSA. DANGER MOUSE PT.13
380ft # @3000 180 hp
390ft # @3500 250 hp
390ft# @4000 300 hp
420 # @4500 350 hp
430 # @5000 400 hp 5000rpm just as the torque was going down hp was going up
420 # @5500 420 hp
410 # @6000 455 hp l
Rod
02-01-2017, 10:13 AM
3000 pounds ....thats pretty light how did you get the car down to that weight?
matt816
02-01-2017, 10:54 AM
Might want to think about a manual brake setup. Your vacuum is going to drop off considerably.
garvir
02-01-2017, 08:33 PM
there is not much left under the hood, the heater and ac are gone, the plastic non ac over the heater hole weighs 8 pounds, no seats except the light drivers seat ( the factory seats weigh about 50 pounds apiece), no carpet, cut about 5 inches off the plastic front wheel covers, saved about 5 pounds. swissed cheese the frame in a few places, but you have to be careful the monte frame is not a stronge frame. carbon fibre drive shaft, small battery in trunk. there might be a few other things i do not remember. Gary
garvir
02-01-2017, 08:40 PM
this is my third cam with 108 lsa, i did add a extra vacuum reserve canister, setting up there next to the vacuum booster. that is a 10" dual vacuum booster, and if more is needed i could put the 12" dual booster off the caprice.
