408maro
06-26-2014, 08:25 AM
Let me start by saying that this is for a 406 small block that will see as much street driving as much as possible. Has a full hydraulic roller setup aswell not sure if it makes any difference
I decided on these summit valve covers http://www.summitracing.com/parts/sum-440400
But also considered these proform ones. And still might if the design is better suit for roller rockers due to the angle
http://www.summitracing.com/parts/pro-141-921/overview/
But this is only half my battle. The next issue is oil leaking from the holes up top of the covers. These have baffles so may not be as bad as my current setup but still want Lil leaks as possible. I hate oil leaks and smoke from hitting the exhaust
I have a holley and edelbrock intake so from my searching need a fitting on the back of the manifold that will fit for the brake booster so I can use the carb port for pcv that will sit on driver side valve cover.
Now on passenger side should I just run a nice big K&n style looking breather or should I do something else?
How about catch cans. Is it necessary?
