View Full Version : 351w Positve Valve Seal issue
rwcstang
03-06-2015, 11:50 AM
Hello Everyone
so I'm having an issue where my Exhaust valve seals keep "popping off" and creates blue smoke through the back, this isn't the first time this has happened & its not in one particular valve either, its only on the exhaust side valves. Motor is still new less than 7k miles, Motor was built by F-P-S by Troy, I talked with Troy but he said he never had an issue with his seal popping off so he sent me an extra set for good measure, so hopefully I can install them this weekend.
is there any reason as to why these things keep slipping off? I know positive valve seals are not ment to move. The heads I'm currently running are Avenger Heads which F-P-S use's in their engine builds.
I believe they used to be canfields recasted as avenger which are built in house by FPS. I also attached pics of the built motor, but no specs on heads. (Sorry for the bad quality) motor is a 351w stroked to a 392w
is there any tips you guys recommend? or should I just pull head outs toss it and purchase a new set of heads?
https://static1.pt-content.com/images/pt/2015/03/495359F119F546A591FDBCD1C6FE7E11_zpslvg7-1.jpg (http://s33.photobucket.com/user/rwctagger/media/495359F1-19F5-46A5-91FD-BCD1C6FE7E11_zpslvg7hz1g.jpg.html)
https://static1.pt-content.com/images/pt/2015/03/0BFD8F5708C74E80A374044EB0124D0B_zpszfg6-1.jpg (http://s33.photobucket.com/user/rwctagger/media/0BFD8F57-08C7-4E80-A374-044EB0124D0B_zpszfg6gzfx.jpg.html)
https://static1.pt-content.com/images/pt/2015/03/5263C420C0CE41F7A583DFA55E4148C8_zps2o1z-1.jpg (http://s33.photobucket.com/user/rwctagger/media/5263C420-C0CE-41F7-A583-DFA55E4148C8_zps2o1za4xq.jpg.html)
https://static1.pt-content.com/images/pt/2015/03/B45726BA1D914ABCB0731FEEC406F2C0_zps5rlm-1.jpg (http://s33.photobucket.com/user/rwctagger/media/B45726BA-1D91-4ABC-B073-1FEEC406F2C0_zps5rlmesxd.jpg.html)
https://static1.pt-content.com/images/pt/2015/03/757094D34ADB4892968CDB4EC971F2E1_zpsb7dj-1.jpg (http://s33.photobucket.com/user/rwctagger/media/757094D3-4ADB-4892-968C-DB4EC971F2E1_zpsb7djotpr.jpg.html)
thanks in advance gents!
