View Full Version : How do you turn a sbc counterclockwise?
19,69camaro
09-08-2015, 05:53 AM
So my issues is that I cannot currently time my engine since there is either the wrong timing cover and or the balancer has slipped on my Mexico block goodwrench 350. I timed it by ear and got it going ok but I would like to verify the mechanical advance curve with a light.
I made a piston stop and was able to get my first mark but when I went to rotate it counterclockwise the balancer bolt loosened up. The only way I can think of doing this is using a prybar/screwdriver and turning the flexplate one tooth at a time.
Anyone know of an easier way?
andrewb70
09-08-2015, 06:19 AM
Take all the plugs out so that it is easier to turn.
19,69camaro
09-08-2015, 06:31 AM
Andrew I tried that and still no luck it just kept loosening up. I guess its going to be the hard way for me
Samckitt
09-08-2015, 07:18 AM
Put lock tight on the bolt, crank it down & let it set for a day, then try.....?
GTOtzel
09-08-2015, 01:00 PM
Try the largest strap wrench you can find and put it on the balancer.
TheJDMan
09-08-2015, 02:22 PM
The other thing you can do is to remove the crank pulley and screw in some longer grade 5 3/8-24 bolts leave them out far enough that you can use the bolts as lever points to bar the crank around.
hotrodneb
09-08-2015, 03:01 PM
My only thought is the flexplate/screwdriver. I don't know---will a starter run backwards?? Negative cable to the post? Wait--NO the bendix won't engage.
kevs79
09-08-2015, 03:34 PM
What about one of those tools that bolt to the crankshaft with the smaller bolts?
kevs79
09-08-2015, 03:35 PM
http://www.ebay.com/itm/like/131382720104?ul_noapp=true&chn=ps&lpid=82
Twentyover
09-18-2015, 09:07 AM
1) Get in the car
2) Turn steering wheel left
3) Proceed
Kenova
09-18-2015, 05:30 PM
I've used this method several times. Probably the easiest solution offered so far.
Ken
JonnyB
09-19-2015, 07:55 AM
You could put 3 long bolts in the balancer where the pulley bolts on and use a pry bar to turn it
19,69camaro
09-21-2015, 06:52 AM
So I ended up just using a pry bar and a 2x4 to push against to turn the flexplate. It wasn't as bad as I thought it would be. The reason was I didn't want to chance messing up the balancer more than it was to begin with and the fact that the mechanical fan got in the way.
On a side note after finding and marking the correct timing position, then correcting the advance curve the engine feels like it gained 30hp everywhere!
