View Full Version : Serpentine conversion question
EODtech
07-16-2016, 09:27 AM
I recently pulled off a serpentine system of a 1989 camaro to put on my 68. I ordered the smog delete pulley, it's the same smooth one that come with the gm kit. The problem I ran into is that the mounting hole is threaded and the bolt I have has a shoulder and goes all the way through and bolts to the head. The shoulder won't fit through the pulley bracket. I tried just using two bolts but it needs to be to long to fit into the bracket. I was thinking about drilling out the threads and just not having fore and aft resistance. Hopefully my pictures help. Its the long bolt in the middle of my pictures and the top bolt of the of the idler pulley in the assembled system.
Joe
Interceptor5588
07-17-2016, 06:30 AM
Drill out the threads, and cut a piece of pipe to fit tightly between the 2 brackets.
EODtech
07-17-2016, 01:48 PM
Good idea. Thanks
blainemeyer
07-18-2016, 04:00 PM
I am in the process of doing the same conversion and am waiting for the smog delete pulley to be delivered. Can I ask which belt you are using ? I bought a Dayco yesterday but turns out to be too short and the part number from the GM kit I believe is 10186167. From your picture yours looks to be a GM part.
Kenova
07-18-2016, 05:36 PM
Here's an idea.
Change your tension pulley from flat to a grooved pulley.
Rather than run your belt under the pulley run it over the top of the tensioner pulley.
Adjust your belt length to put the tensioner pulley in the correct position.
This would eliminate the big delete pulley as well as the idler pulley under it.
Ken
EODtech
07-18-2016, 09:22 PM
I haven't bought a belt yet, I was just going to get the one gm suggested. The bottom picture is one I stole off google images. If I find the right one I will let you know
- - - Updated - - -
Here's an idea.
Ken
That sounds like a good, but I already have both pulleys and I plan to add ac in the next year.
130fe
07-19-2016, 04:19 AM
I ran that setup without the smog pump delete pulley. Just use the 968k6 belt listed in this web link. It worked fine without any issues.
http://www.thirdgen.org/serpentine/
EODtech
07-19-2016, 01:44 PM
Do you know if that was a 97 or 98 inch belt
BonzoHansen
07-19-2016, 03:04 PM
No reason to remove the smog idler if you already have it. I run that one and looks like belt 5060968
EODtech
07-19-2016, 04:18 PM
Yes, but it would be nice to return it and get $50 back
blainemeyer
07-19-2016, 05:40 PM
I was able to get the GM belt numbers off your picture, 6pk2470 88986814, which looks to be a Dayco 5060970 which is 97.05 inches long. I just got my smog delete pulley and the one I got already has the spacers built in and the hole have no threads. The second picture shows it mounted in the larger pulley bracket. I got mine from EBay and the part number is 10186167. Here is a link to a similar one http://www.ebay.com/itm/New-Accessory-Belt-Idler-Pulley-Chevy-Chevrolet-Camaro-Pontiac-Firebird-10186167-/371532955593?hash=item568116ffc9:g:ob4AAOSwsTxXjbs 3&vxp=mtr. Hope this helps and its not too little too late.
129514
EODtech
07-19-2016, 06:33 PM
129514
Nice find, thanks
blainemeyer
07-26-2016, 03:40 PM
I wanted everyone to know that using the Dayco 5060970 97.05in belt along with the 4-1/2 in pulley that came with my smog delete bracket, the belt is too short. I just ordered a small 3in idler pulley like the in the picture at the beginning of this thread that I hope will resolve my problem.
BonzoHansen
07-26-2016, 07:11 PM
Why not just get a longer belt?
blainemeyer
07-28-2016, 04:04 PM
Could have done that but how do you know what length belt to get ?
BonzoHansen
07-28-2016, 04:23 PM
How much longer do you need? Dayco site has a way to look up by length.
http://www.daycoproducts.com/online-catalog-1?part_type=20&effective_length=98&num_ribs=6
Chad-1stGen
07-28-2016, 07:22 PM
Not sure why the GM kit supplies the bracket for smog pumps and then wants you to run a smog pump pulley. If you go the the junk yard you can grab the passenger side bracket for the air conditioner off of a heavy truck and it won't have the extra mount area for a smog pump. I've had luck with the extended cap trucks as the GVW has to be above a certain amount to not use smog pumps.
H2Ogbodies
08-01-2016, 02:48 PM
Agreed! I too don't use the smog pump provision brackets either-they look hideous. I prefer the keep a smooth RH bracket look. Not sure if you guys have the room but I also run an adapter kit to use a GM 140A alternator as seen on this truck...
blainemeyer
08-03-2016, 04:21 PM
Smaller 3in idler pulley worked with the 97.05 belt.
