View Full Version : Where to get braided power steering lines?
Centralia69Camaro
02-19-2015, 07:17 AM
I just realized i have no power steering lines. I must have left them on my small block when i sold it now i need some new ones. Is there a good place to get them cheaper than like summit etc?
CarlC
02-19-2015, 09:11 AM
http://www.mcmaster.com/#braided-stainless-steel-hose/=vz90lu
jlwdvm
02-19-2015, 12:34 PM
I ordered some Fragola hose and steel ends and made my own. Their hose is rated for 3000psi.
TheJDMan
02-19-2015, 03:49 PM
I went to the local NAPA store and purchased the necessary ends and some -6 hydraulic hose then took the items home and fitted everything then took the hoses back to NAPA and they crimped the ends on the hoses. Total cost was about $40 and the hoses are rated at 4000psi.
Spork82
02-19-2015, 04:47 PM
Did you use their 6000 series ptfe hose or the blue rubber?
jlwdvm
02-20-2015, 10:31 AM
I used the 6000 in stainless...didn't want the blue color.
Spork82
02-20-2015, 02:52 PM
Awesome thanks, I just ordered up some for my car.
1989GTA
02-20-2015, 07:21 PM
That is what I did and used the 6000 series.
Spork82
03-01-2015, 07:44 PM
Question for you guys. I am using the GM type II pump with the plastic clip on reservoir. It has a plastic inlet for the return line. I don't think the -6 PTFE will fit over it.
I think my options are:
Cut the inlet off and install a -6 port
Use adapters on the rack and increase the size of the return hose to -8 or -10
Replace the reservoir with an aluminum one.
Any input?
Spork82
03-01-2015, 10:15 PM
Did some research and Detriot speed has a 1/4 npt to -6 steel adapter to convert their plastic reservoir to AN. I will buy it from Aeroquip as it's only $4 compared to $16 from DSE.
XLexusTech
05-29-2016, 03:44 AM
So does that return nipple thread in with npt threads?
z28cp
06-04-2016, 09:59 AM
Or just use a non teflon lined hose for the return. There's no pressure there.
