View Full Version : does any one have a vapor lock solution ?
68metal
06-23-2015, 02:13 PM
My BBC, electric fans, and mechanical fuel pump is showing signs of vapor lock when the engine gets hot. I have a 2" cowl hood but I guess the engine compartment still has too much heat in it. I'm told this is a common issue with BBC in a small engine compartment like a Camaro. I'm hoping someone has a solution.
Thanks in adavance,
Max
jprewitt
06-23-2015, 03:14 PM
Mine did as well until I upgraded to an electric pump with a return line to recirculate the fuel and keep it cool.
astroracer
06-25-2015, 02:26 PM
Like above^^^^. Can I ask where your fuel lines are routed right now? If they are anywhere within 3 or 4 inches of your headers or collectors heat will be a problem. Routing the lines away from the exhaust is one solution.
Also, how is your carb mounted to the intake? Just one gasket, otherwise it is directly on the intake? if so a phenolic spacer will go a long way to keeping the float bowls cooler.
Mark
JustJohn
06-26-2015, 03:55 AM
If it's really bad, you could install one of these:
http://www.terrysjag.com/category/XJS-FUEL-COOLER.html
CarlC
06-26-2015, 02:47 PM
Do you have a carburetor heat shied installed?
68metal
06-29-2015, 08:59 PM
I don't have one installed
68metal
06-29-2015, 09:00 PM
I assume it cools the fuel ?
68metal
06-29-2015, 09:01 PM
06-30-2015, 01:05 PM
Get a carb heat shield, and install a fuel filter for an air conditioned car. If you can't find one for a BB Camaro OEM style, look for a 68 Cadillac fuel filter. It goes between the fuel pump and carb, has a small return line back to the tank with a jet in the return line.
http://www.ebay.com/itm/like/231541686714?lpid=82&chn=ps
68metal
07-12-2015, 12:37 PM
Thanks David I'll try that
68metal
07-12-2015, 12:39 PM
Fuel line and mechanical fuel pump is within inches of header
sam 74
07-14-2015, 08:15 PM
if you can't move the fuel line wrap it in heat sheild, as for the pump electric would eliminate a ton of heat soak into the fuel. also a carb spacer will help just stay away from the metal ones.
