View Full Version : How to keep my Aluminum Block looking new ?
68metal
03-17-2014, 06:58 PM
My BBC block and heads are showing signs of oxidation. Any suggestions of how to keep them looking new ?
markss28
04-01-2014, 08:59 AM
I would think u could could just clean it up and then spray a high temp clear coat
Knoxferatu
04-05-2014, 09:12 AM
I've often wondered why nobody ever has these items anodized.
Skip Fix
04-05-2014, 12:50 PM
http://www.aircraftspruce.com/catalog/cspages/alodine1201.php
Heard this stuff does the job and doe not really elave it golden. I am going to try it on some aluminum heads for my Pontiac motor I'm building for the 81.
You can't anodize cast aluminum, as a rule. Certainly not larger castings typically given a "sand blast" finish.
Not, at least in the way you'd expect- bright silver. The same mixed chemicals in the same order give cast a dark mottled look.
Billet/extruded only to get a bright finish.
