View Full Version : LS1 Ram Air Intake Manifold
69LS1SixSpeed
02-12-2015, 07:56 AM
Anyone out there have any experience with Scott Pro Speed Parts (hitechmotorsport/Ebay)? I've attached a picture of their product listing. I have a 69 Camaro with a 2000 Trans Am LS1/6 speed and want to switch out the factory composite manifold. It's basically stock now except for headers and FAST 92mm billet throttle body. I plan on installing a Comp Cams Thumper cam with upgraded valve springs and push rods shortly and want to change the factory intake while I perform the cam change.
My car is basically a "cruiser" now (Picture attached)....but I want the old sound of a lumpy cam and the "hi tech" look of the sheet metal intake manifold plus some power increase! I would appreciate your input on this manifold as the pricing is very reasonable. I have to confirm it will fit under my factory cowl hood before I go much farther!
Chuck
Charlotte, NC
andrewb70
02-12-2015, 08:04 AM
I believe these have been dissected by various people on LS1tech and the consensus is that they are cheap overseas junk that is just made for looks.
cornfedbill
02-12-2015, 08:29 AM
That is good to know. I do know that the factory intakes are severely limited by their low profile. I really wish we could have had more room to lift the runners and to have a better transition from the plenum. This type of design has potential. Too bad the execution seems to be poor.
I know if the transition from the plenum to the runners is too sharp, the effective flow area will be choked and will act like a smaller runner. We observed that many times while developing the LS7 intake. I can tell you a thousand ways to do it wrong...
andrewb70
02-12-2015, 08:48 AM
Here are a couple of relevant links:
http://ls1tech.com/forums/generation-iv-external-engine/1676842-ls-fabricated-intakes.html
http://onthedyno.com/GM-LS-motor/article/intake-test-stock-vs-procomp-fabricated-ls3/
Schwartz Performance
02-12-2015, 09:25 AM
Many places have been importing them. I mean for $500-600 it's a sweet looking manifold.. But I'd buy it for looks before performance. I wouldn't care if I lost 20hp, they're cheap and cool! lol.
I bought & sold a few last year for both the LS3 and LS1. They do look nice from the outside and come with gaskets & bolts.
As far as modifying them, it has been done and can be done for not a lot of $$.. A USA made one is about $2500.. For about $400-500 you could have a fab shop cut off the top of the knockoff one and probably get closer with HP.
-Dale
Skip Fix
02-12-2015, 04:21 PM
For you LS guys-why did almost all of the LS based motors in the Engine Masters this year use a EFI system on a carb style Victor type intake?
andrewb70
02-12-2015, 04:34 PM
Because they work better given the rules and the scoring of EMC...
https://image.adam.automotive.com/f/77509819/2014%20EMC%20Engine%20Masters%20Rules%20as%20of%20 8%2016%202014.pdf
Skip Fix
02-13-2015, 01:00 PM
Since EMC is about good average TQ/HP I would think then that intake would be good for LS motors stuffed in older cars that have the hood clearance.
