View Full Version : drivability with a high ram or sheet metal intake on ls1
chevnut55
03-06-2016, 05:32 AM
I have been reading up on the intake manifold comparison tests but no one talks about how they act on low end regular driving.
Would a high ram or sheet metal intake work on a stock ls ?
The ls1 in my 69 Camaro has a asa cam and dynotech headers , I am looking more to dress it up than performance and would like to install a intake before I have it re-tuned.
Before anyone suggests using a fast or stock looking intake , I do not want the stock look.
andrewb70
03-06-2016, 07:11 AM
I have a Hi-Ram with dual DBW throttle bodies, ASA cam in a 5.3L installed in my Cougar. It drives great.
dirty rick
03-06-2016, 08:29 AM
Drive ability will not change much, some loss of low end torque. Probably additional loss of low end torque with a cam that suits the intake. Air valve size and linkage design will also change throttle feel dramatically. To the point of making really choppy on a manual trans.
chevnut55
03-06-2016, 02:11 PM
Thanks for the info. Im looking at the omega 85mm qualifier intake. I have a 4l60e with a supposed 3200 converter from mad dog trans.. its more like 1800.
I already lost a lot of low end power and torque with the cam but it has not been tuned yet and idle is too low.
andrewb70
03-06-2016, 04:25 PM
No offense, but that intake looks terrible and will probably cost you power and add 30 pounds.
TheJDMan
03-06-2016, 08:26 PM
I agree with Andrew that is an ugly manifold! You might want to read this HotRod article before you swap intakes.
http://www.hotrod.com/features/1507-20-ls1-intake-manifolds-tested/
chevnut55
03-07-2016, 06:06 AM
I do like the holly high ram best. Really I wish I could afford to either go with the omega downdraft efi stack , but if I had that much to spend I would spend a bit more and go with a supercharger.
Like I said its not for power in this car its for looks. I have a drag car and have a autox/ track car, the Camaro is my driver /road trip car.
chpr1972
03-21-2016, 09:29 AM
Nothing looks better, unless a 14/71 blower, than an old school tunnel ram with 2 throttle bodies. Even the TPI does not distract from the look much. Some people think that the injectors or NOS! lol According to the guy who machined my motor with a 750 holly on a torque intake it had 500/525 . With the dual Holly throttle bodies on the tunnel ram my motor is estimated to be 575/600 hp. With a TKO600 and 3:50:1 9" 25.5 " tires It is as tame as with the carb. I do not have an LS but is a 489 BBC
68Cuda440
03-21-2016, 08:14 PM
Pictures! Here is mine (also not an LS), sorry about the hijack!!! Have not driven it yet. But previous experience with carb tunnel rams I expect no loss in drivability.
125209
