Twentyover
01-31-2017, 10:16 AM
In the mid-70’s some people were putting 350 cranks on 400 Chevys to get a 377, bigger inches with better bore stroke ratio, This was in the days when the only people that made blocks were guys like Pink and Donovan, so you were pretty much stuck with stock SBC blocks. Since the 400 used a larger main than the 350, bearing spacers were used to take up the gap between the larger 400 main bearing saddles and the smaller 350 main journals.
I’m in a similar situation with an old MG engine I’m working with. There are no quality high load bearings available. While it looks like I have a rod bearing solution (early small journal SBC bearings), there are no quality main bearings available that are close. The fast guys in the UK running this engine pound out the mains about every 4-6 weekends, watching their oil pressure gauges, changing mains out when the oil pressure starts to drop away.
Nominal main journal diameter is 2.3745” and main bearing bore is 2.5212, design bearing length is 0.947 for 5 of the 7 mains, center and rear are 1.065 long. Thrust is taken up with 4 crescent shape bearings on each side of the bearing saddle and cap. Found some bearings that are close, but none of these are without issue, specifically to get the bearing bore down to the value it needs to be would take a pretty huge cut on the main caps and I’d also need to cut the main saddles. So my thinking turned to using a good tri-metal bearing for a different application, with a bearing spacer, like they did in the long forgotten past (except to us guys with lots of gray hair, if we still have hair).
Does anyone know who can make a set of custom bearing spacers? Any known (to people that aren’t me) problems with this type of plan?
I’ve got a good machinist, but I’m thinking this is kind of more specialized. Any experience with making them?
Bottom line is…..
Help!! Mr Wizard!!! (another arcane reference those my age will understand)
Bottom line is…..
