View Full Version : The Fabrication Forum
- Sandpaper for stainless (0 replies)
- Beginner With DC TIG (27 replies)
- User list of services offered? (2 replies)
- Learning to weld (24 replies)
- Silicone bronze technique for structural integrity (4 replies)
- Metal grade for watts link (1 replies)
- Exhaust fabrication question (13 replies)
- Hammer forming (1 replies)
- Gaps between firewall and roll cage (2 replies)
- TIG settings for 3 bolt flange? (5 replies)
- TIG welding is hard (8 replies)
- Anyone familiar with factory welds on frames? (5 replies)
- Chassis Welding - warping (5 replies)
- Fabbing 68 nova frame. (2 replies)
- CNC fab work needed -- aluminum 1/2" ring steering wheel hub adapter (0 replies)
- 1967 Firebird mini tub gas tank (3 replies)
- Best chassis materials? (2 replies)
- CNC Coil Covers (0 replies)
- 3rd gen Camaro fabricated sub structure for front bumper cover. (0 replies)
- Oil / transmission cooling line (1 replies)
- 1968 Camaro NEED HELP and direction, measurements do not add up (0 replies)
- 3/16" Welds - What do you think? (4 replies)
- Rack and Pinion fabrication (4 replies)
- Custom power steering hose made (4 replies)
- flush mount windows (3 replies)
- 908/3 Go Kart (11 replies)
- frame notching (2 replies)
- Rodman Nibbler. Who has one? (2 replies)
- Hurst shifter blues, what do you do? (5 replies)
- looking for Camaro with Cadillac V interior (1 replies)
- LS a/c notch for 67 Camaro (1 replies)
- Custom shock tower brace (3 replies)
- Ford Econoline Pedal Car (13 replies)
- Tube bending made easy, The Fabricator Series on youtube. (1 replies)
- Mounting Body? (3 replies)
- '68 Mustang Trunk and Interior Sheet Metal (15 replies)
- Custom all steel fender vent (7 replies)
- Custom Billet Air Filter Lids! (3 replies)
- Custom lenses? (3 replies)
- subframe-to-unibody: mounts & bushing methods (0 replies)
- Where did you learn to fabricate? (13 replies)
- Aluminum sheet forming (1 replies)
- Homemade Subframe connectors? 2nd Gen Camaro (0 replies)
- A body Frame question. (2 replies)
- Auto Rod Tech's metal shaping and fabrication thread (105 replies)
- Welding Nuts - OK Fab guys, chime in. (8 replies)
- Big Block CAD File? (1 replies)
- Anyone have a 3D printer? (6 replies)
- Intake manifold upper plenum (2 replies)
- 2012 Camaro IRS into a 67 Camaro (6 replies)
- Anybody got Waterjet cutter? (9 replies)
- Routing exhaust through cross members? (9 replies)
- ideas for mounting (2 replies)
- bead rolling for strength (2 replies)
- LONGEVITY plasma cutter (2 replies)
- Building a Flat Top Bender (2 replies)
- Inner Fenders 72 Nova (0 replies)
- Another quick project (15 replies)
- Custom Billet Grille Fabrication (3 replies)
- Rool-a-Round Metal Cutoff Rack (8 replies)
- Welding on a unibody (5 replies)
- Tube Bending Choices (11 replies)
- Need help in Las Vegas (21 replies)
- garage built tire rack (1 replies)
- Drive Adapter for my HF Elec Pipe Threader (1 replies)
- 9" Ford 3D CAD wanted (0 replies)
- Custom welding cart - let's see them (7 replies)
- MIG or TIG (15 replies)
- MIG Welding 20 ga sheet metal, argon or CO2 (8 replies)
- where to buy round and square steel tubing (4 replies)
- Question on fab process to choose (2 replies)
- mini tub kits (4 replies)
- Mini Tubs (6 replies)
- Frame Stiffing ERW vs DOM (6 replies)
- Something other than Plastic (4 replies)
- Built a Cheap Ast radius bender (2 replies)
- Need a TIG welder in San Diego (3 replies)
- Tube Notching With a Lathe (4 replies)
- Are Miller & Hobart welders made in the same factory? (1 replies)
- Baileigh TN-250 Tubing Notcher (13 replies)
- Shaving bumpers (12 replies)
- Chassis Jig (9 replies)
- baffles and sump for carb tank (2 replies)
- Fuel tank construction (56 replies)
- Muggy Weld ?? (5 replies)
- could someone convert a stlprt (soldiworks) file to autocad for me? (3 replies)
- How about a Tig welding aluminum discussion? (23 replies)
- Welding table construction advice needed (9 replies)
- Need a good heat shield material (2 replies)
- Montana (0 replies)
- bumpers (5 replies)
- Ls2 ac/alt bracket help (4 replies)
- Chassis Jig (0 replies)
- Ideas for my engine bay cover (2 replies)
- The art of purge welding( back purging) (25 replies)
- Vespel (4 replies)
- Need a Fab guy. TKO 600 adapter (0 replies)
- Machine shop hours.... (11 replies)
- Metal Shaping @ 2012 Santa Cruz Metal Meet (23 replies)
- TIG welding cast aluminum (14 replies)
- Mig wire size for Quadralink install (11 replies)
- Before I spend $60 on ebay, anyone capable of making a straight LS thermostat housing (3 replies)
- New blog post about using shock simulators instead of real shocks (0 replies)
- Custom Intake wanted (1 replies)
- Anyone use BobCAD/CAM? (4 replies)
- CAD/Design Help Requested for Tube Chassis Please! (2 replies)
- welding on threaded aluminum (10 replies)
- CNC Tube bending (4 replies)
- Custom fuel tank with VaporWorx gear (5 replies)
- Sheet aluminum for polishing (3 replies)
- FUSE welding from Vibrant ??? (1 replies)
- CNC Machining? (10 replies)
- Anyone with a lathe willing to make something for me? (16 replies)
- 2x3 frame thickness question (9 replies)
- covertible top and DSE tubs! (15 replies)
- Filling Seams with silicon bronze (22 replies)
- Rotted Body Mount (5 replies)
- CNC Machinists/CAD designers, I need advice on creating my invention. (10 replies)
- Firewall Steel question (12 replies)
- Cutting sheet metal (15 replies)
- Zen and the art of tube notching... (4 replies)
- Carbon fiber shatter? (5 replies)
- where to get cool hole punching tool (7 replies)
- need some advice on billet strength for serpentine setup (8 replies)
- Chrome-moly vs mild steel for cage (7 replies)
- welding stainless with a mig (4 replies)
- Welders and Fabricators, is it a taught skill or something you can learn alone? (24 replies)
- elongating a spoiler? (4 replies)
- shops/people in knoxville (3 replies)
- Preferred weld thru primer (6 replies)
- Tube Chassis for Protouring Cuda (9 replies)
- Rotisserie tube size and thickness (6 replies)
- Thermo Dynamics Cutmaster 38. Good/bad...? (4 replies)
- drilling axles, rotors or drums for different lug pattern (2 replies)
- Upper Control Arm Bushing Sleeves (0 replies)
- look what im making!! (19 replies)
- Welding Mods to GM A-body Frame (2 replies)
- aluminum thickness for spoiler (6 replies)
- Lookin for good fab videos or books or website (0 replies)
- Fabbing alt bracket and guage panel? (2 replies)
- Headers (1 replies)
- Looking for DXF image (0 replies)
- proper way to build custom gauge housing (2 replies)
- BendTech? (10 replies)
- Help getting started with a bead roller. (0 replies)
- 3in. Aluminum tubing (5 replies)
- Modeling frame rails in autocad inventor? (4 replies)
- Yet another AutoCad Inventor Question... (16 replies)
- AutoCad Inventor help - Need to export/convert to DXF (7 replies)
- fender rolling (3 replies)
- 1 3/4" chromoly thick wall (4 replies)
- watts link (15 replies)
- LS motor mount hole locations. (1 replies)
- I need some dims from stock Chevrolet motor mount "clam shell" brackets. (0 replies)
- Boxing a frame, questions? (10 replies)
- English Wheel Build (11 replies)
- '69 rear bumper on a '67 Camaro...... (2 replies)
- Laser or water jet work needed (4 replies)
- off topic help on repairing dented 7075 extruded section (0 replies)
- Custom Hub Adaptor for Steering Wheel (4 replies)
- JCG Wheel Stands (14 replies)
- Steel Shape Charts w/ weights per ft (1 replies)
- Anyone on the board have access to a CNC & CNC mini Lath and Plastic? (1 replies)
- Anyone have access to a SLS machine ? (0 replies)
- Millermatic 180 or 211 (9 replies)
- How much tube for a full roll cage? (3 replies)
- Tips for removing the color from welded stainless steel (2 replies)
- Welding mild steel and stainless (4 replies)
- 67 Mustang Fender Flaring Question (2 replies)
- using the correct polarity when welding (0 replies)
- Using 4130 for sheet metal repairs (8 replies)
- Cold Air intake from SLS material (6 replies)
- CNC aluminum job questions (4 replies)
- welding frame-how to splice (5 replies)
- Rivet nut / nut insert tools (50 replies)
- magnetic materials (0 replies)
- eMachineShop.com (16 replies)
- Working with Copper (3 replies)
- connecting tubes at a low angle (4 replies)
- Multiplaz, plasma kutter and welder, anyone? (5 replies)
- AutoCad 3d question (using inventor 2010) (10 replies)
- Rod end experts -- got a question (20 replies)
- fuel cell fabrication tips (5 replies)
- need pricing assistence on fab work (3 replies)
- Brake caliper bracket design/fabrication (3 replies)
- 1st Gen Custom Valance (2 replies)
- Autocad headers help (9 replies)
- Crossmember Fabrication (7 replies)
- Neat Tube Notching pattern creater - free (0 replies)
- Houston (area) mill work needed (0 replies)
- Bracket Spacer needed.. aluminum or steel (5 replies)
- Tig conversion kit? (4 replies)
- who can make some brackets for me? (15 replies)
- Who here does water jet cutting??? (0 replies)
- Metal type and thickness for bracing? (1 replies)
- henrob 2000 (11 replies)
- My new battery tray (25 replies)
- Well been looking for small tig,,,, (2 replies)
- MIG beginner and I need advice (14 replies)
- Adding "fish plates" to a welded joint? (21 replies)
- 1st Gen F-Body Body Cart (9 replies)
- Welding steel under tension????? (5 replies)
- Glovebox wiper install pics (9 replies)
- anyone make a homemade tube bending die? (8 replies)
- I need a welder recommendation (27 replies)
- Recirculating air filtration (3 replies)
- car rotisserie / spit (4 replies)
- wishbone advice (7 replies)
- Mass Welding & Surface Conditioning (1 replies)
- Alibre Design Standard (5 replies)
- Suitable material for a coolant reservoir? (5 replies)
- Annealing Cold rolled 16g steel (3 replies)
- Custom CNC / Fab guys (10 replies)
- how to lay out an ellispe (11 replies)
- tig welding stainless to mild steel (7 replies)
- square or round tubing strength after damage (3 replies)
- Template for Caliper Adapter Bracket (1 replies)
- Roll bar connection (13 replies)
- Motor and transmission mounts (0 replies)
- CAD freeware? (11 replies)
- Noob question -- 2-1/16" holes in .25" aluminum? (5 replies)
- Cool U weld it brackets and parts (1 replies)
- pot metal and sheet metal (6 replies)
- Stainless welded seam tubing........ (0 replies)
- Will this work or stress the body too much? (14 replies)
- A-Body Frame (1 replies)
- minimizing distortion (0 replies)
- The Official Tube Notching Thread (34 replies)
- Air Ducts (5 replies)
- 66 Chevelle Body Cart Questions (4 replies)
- Looking for direction... (11 replies)
- School question (6 replies)
- critque these welds please (25 replies)
- Sheet metal brake (1 replies)
- Building a pro-touring crew cab truck (3 replies)
- My first header. (3 replies)
- Splined Shafts (4 replies)
- What size square tubing for building a frame? (37 replies)
- burn through? (13 replies)
- weld or rivet? (4 replies)
- 14ga frame horns for engine (14 replies)
- Will the mini tub install process harm exterior paint? (3 replies)
- welding on fuel tank (24 replies)
- Body mounting solid vs bushed (3 replies)
- Arc welder help. (3 replies)
- Engine Covers (3 replies)
- Serpentine setup (18 replies)
- The Official Tube Bending Thread (73 replies)
- What medium duty box and pan brake to get? (6 replies)
- Toyota Supra engine into 1989 Transam? (17 replies)
