View Full Version : Recirculating air filtration
Junkyard Johnney
01-13-2010, 08:33 PM
In concern of working indoors during long winter hours up north here sometimes the air gets pretty thick. Pumping the smoke outdoors along with ever growing expensive heat is not an option. Falling over dead at 60 years old, which isn't to far off the 60 part anyway, from smoke inhalation isn't appealing. A buddy has a small recirculating filtration unit hung up in his small work shop, my shop is 30x40. I never used to think about any of this but age seems to bring about changes of viewpoints among other things. Any fab guys with plasma tables and or body guys got any input on economical units on the market. Appreciate any ideas on this subject. Thanks...
Tom Welch
01-14-2010, 05:18 PM
maybe some portable air filtration unit like the hazmat guys use, they have HEPA filters in them.
toxicz28
01-14-2010, 06:30 PM
Try this :smoke:
http://www.google.com/search?hl=en&q=industrial+smoke+eaters&aq=0c&oq=insmoke+eaters&aqi=g-c1
Jim Nilsen
01-31-2010, 09:36 PM
Depending on the fumes it is a neccessity to remove them as it may be impossible to get them out before the damage can be done to your lungs. HEPA filters are great at removing dust and smoke but some of the carcinegins are vapors that will not get cuaght. HEPA filters also can clog rather quickly for the expense and that is why hazmat work is very expensive. The asbestos crews I have seen working can go thru them at a rate that would make your heating bill seem mild.
Get the stuff out and be done with it. The thing that really gets tough is when you are trying to supply a paint booth with fresh and warm enough air all at the same time, which can make painting in the winter in some areas a lot more expensive because of the heating of the incoming air to the building.
If you are welding and you choose to use welding rod you need to remove those fumes absolutely as they can cause real motor function problems of the body from the reseach I have read that can be worse than alsheimers disease. The choice of using a mig can really help and a tig is a good choice to to keep the smoke and fumes down but any welding fumes in mass quantities should be removed.
If you really want to get the best info you can go to OSHA.gov and see what the requirements are in the industry and then decide from there.
