astroracer
01-22-2017, 09:51 AM
I've had this Rodman nibbler for years. It works well and it gets used but it is a bit uncontrollable when hand held and only a bit better when clamped to the bench.
https://static1.pt-content.com/images/pt/2017/01/MVC008Svi-1.jpg
https://static1.pt-content.com/images/pt/2017/01/MVC005Svi-1.jpg
I saw a post on Homemade Tools where a guy built a box to mount his and thought that would be the berries. I never pursued it though, until yesterday. :)
I got to thinking, I don't need a huge box for this thing, just something big enough to be able to support the sheet I am working with. I thought a little table would be perfect. I have one of those Cheapish Craftsman router tables, aluminum top with sheet metal legs... Hmm.
I dug it out and took off the router and fence and started designing.
This is the underneath where the router bolts up.
https://static1.pt-content.com/images/pt/2017/01/MVC003Svi-1.jpg
I made a plug out of 1/2" plywood as a spacer.
https://static1.pt-content.com/images/pt/2017/01/MVC004Svi-1.jpg
Drilled the three holes for screws and made a base plate to mount the nibbler to.
https://static1.pt-content.com/images/pt/2017/01/MVC014Svi-1.jpg
The notch at the top captures the bottom of the table, at the rear, where the blade guard/dust collector attaches. I wont be using any of that for the nibbler version.
https://static1.pt-content.com/images/pt/2017/01/MVC006Svi-1.jpg
With the base plate made and attached I got the mounts for the nibble made. This is simply two pieces of 3/4 lumber screwed to the base plate from the top.
https://static1.pt-content.com/images/pt/2017/01/MVC010Svi-1.jpg
This clamps the nibbler mounting head between the wood with that 3/8th's bolt. It is very stout, during test runs the nibbler didn't bounce or vibrate at all.
https://static1.pt-content.com/images/pt/2017/01/MVC011Svi-2.jpg
Getting the drill motor attached was pretty easy. I chucked it up to the drive post on the nibbler and strapped in place with a piece of pipe hanger. :) Didn't even have to drill holes, they were both there.
https://static1.pt-content.com/images/pt/2017/01/MVC020Svi-2.jpg
Looking from underneath.
https://static1.pt-content.com/images/pt/2017/01/MVC024Svi-1.jpg
It worked well on a couple of quick test samples. We'll see how it does on a real world job.
https://static1.pt-content.com/images/pt/2017/01/MVC023Svi-1.jpg
https://static1.pt-content.com/images/pt/2017/01/MVC019Svi-1.jpg
