View Full Version : The art of purge welding( back purging)
80proZ
08-22-2012, 04:51 PM
Me (most people call me Eric) parsonsj(most people call him John I believe) got into a discussion on another thread about purge welding stainless tube and came to the conclusion that I share my knowledge.
A little backround first. I've been doing fabrication and welding for about 20 years. Have done sheet metal fab and tube, pipe work for most of those years and have learned quite a bit. Have been doing sanitary stainless tube for about 9 years now. I get to make some neat and nice stuff sometimes.
I'll start this with my welder I'll be using.
https://static1.pt-content.com/images/pt/2012/08/5dd217c6-1.jpg
It's a miller Econotig I picked up used. Good welder for what I use it for.
I run an air cooled torch with a gas lens and 3/32 2% thoriated tungsten for most of the welding I do. And pure argon gas
https://static1.pt-content.com/images/pt/2012/08/e176f62c-1.jpg
I'll be using a piece of 2.5" 304L SS sanitary tube for this, with a ferrule on each side.
https://static1.pt-content.com/images/pt/2012/08/e99b8803-1.jpg
I'll purge weld one joint and just weld the other joint without a purge. The particular piece was an old product line and has a calcium build up that needs to be cleaned out in order for it to properly be purge welded
https://static1.pt-content.com/images/pt/2012/08/ad07be69-1.jpg
https://static1.pt-content.com/images/pt/2012/08/963a8de4-1.jpg
This is welded using a method called walking the cup. Where as you rest your TIG cup on the tube and literally "walk" it around the tube while welding. This does two things. Allows you to make a much longer weld before you need to reposition and will make a much more uniform weld. The less starts and stops you have, the better.
https://static1.pt-content.com/images/pt/2012/08/3e598679-1.jpg
I like my welds nice and clean.
https://static1.pt-content.com/images/pt/2012/08/29a1e8b6-1.jpg
Here's the inside. Could have been less heat and there wouldn't be no sugaring.
https://static1.pt-content.com/images/pt/2012/08/d92f34b7-1.jpg
Spin my piece and prep the other side for a purge weld. I keep a variety of different adapters for various tube sizes and different applications.
https://static1.pt-content.com/images/pt/2012/08/cd4221cb-1.jpg
Most of my adapters have a quick connect for easy changes to other purge cap sizes.
https://static1.pt-content.com/images/pt/2012/08/8b595b06-1.jpg
When purging, you're removing all the atmosphere gases from the tube and replacing in with argon. You want to close off all other openings. I use tape or sometimes aluminum foil. Unfortunately I forgot my purge hose on a job so I'll continue this tomorrow and get a little more in depth on it.
Hope you enjoy.
Twentyover
08-22-2012, 05:41 PM
How do you bleed argon in to the back volume? A second regulator, a T off the torch line, or? Do you purge for a given period of time prior to striking an arc? If so, how do you determine the time value?
parsonsj
08-22-2012, 06:30 PM
Eric, nice stuff. Looking forward to the "rest of the story".
dontlifttoshift
08-23-2012, 04:48 AM
Thanks for posting that Eric.
3/32 tungsten? I guess when you are walking it helps spread out the arc. Can't wait the see the rest.
WS6
08-23-2012, 04:21 PM
By walking do you mean you kind of rock side to side and pull back at the same time? Like you'd do with a heavy box or something you don't want to slide but can't lift either?
Good stuff. Thanks for posting.
80proZ
08-23-2012, 04:22 PM
Twenty I use a Y fitting on my flow meter. Better way would be a dual flow meter and best would be running off of another bottle.
https://static1.pt-content.com/images/pt/2012/08/8724cf28-1.jpg
Purge time will depend on tube size and the actual size of your part. I failed to mention that when you're closing off all other openings, you'll need a relief hole somewhere. Usually at the highest point of your part as argon is heavier than air. This will allow it to vent and fill with argon. All in all this piece took about 5 to 7 minutes to complete. About 2 minutes to purge and the rest on the welding and clean up.
https://static1.pt-content.com/images/pt/2012/08/26cf30d5-1.jpg
One half welded. Started at the very bottom and worked my way to the top and a little beyond.
https://static1.pt-content.com/images/pt/2012/08/861abce4-1.jpg
Fully welded. When you start on your previous start, always move back about a 1/4". This will ensure your purge at your start. And go past your previous stop about the same. This is where most people fail a sanitary tube test. The starts and stops.
Also notice the color of the weld is much darker than what most people look for. Now look at the inside
https://static1.pt-content.com/images/pt/2012/08/76442da5-1.jpg
https://static1.pt-content.com/images/pt/2012/08/ab1d0e47-1.jpg
https://static1.pt-content.com/images/pt/2012/08/4b8ef5be-1.jpg
That's a good purge weld. Very nice color on the inside( good purge). You can see a little hiccup in the last photo, which is a start. But it's still good.
3/32 tungsten is just a preference.
Now I will say this. I wouldn't waste my time purge welding an exhaust system but I would do it with headers and any turbo parts. It is a stronger weld than an non purged weld and will hold up way longer to heat cycling. I've never had a failure. Here's a quick pic of the exhaust I did for my camaro. Totally free and built by me. X pipe is 2 90s with the heels cut out. Don't have any of it finished but it's been under my car for about 3 years without a problem. Non of it is purge welded. But it is TIGed!
https://static1.pt-content.com/images/pt/2012/08/24d2ee54-1.jpg
Thanks for looking.
80proZ
08-23-2012, 04:53 PM
Yes WS6. Except you go forward. If you look close at the pic of the first half weld, you can see the cup tracks.
diesel25lrs
08-23-2012, 05:57 PM
Eric- first off- you are a bad ass welder! Thanks for sharing your knowledge! I'm getting ready to weld up my SS 3" exhaust with trimix, SS wire & MIG- any recommendations? Only tools available...
parsonsj
08-23-2012, 06:06 PM
Yep, outstanding. Can you tell us more about "cup-walking"? Angles? "Drag" the tungsten (forwards? backwards?)
Backing up and rolling over on stops and starts is crucial for aluminum tank welding too. Otherwise you end up with tiny pinhole leaks that show up at around 3-4 psi.
80proZ
08-24-2012, 07:24 AM
Thanks guys. Diesel , make sure you make some practice runs on some scrap. I personally would pull when mig welding tube. Some people would argue the penetration factor of push vs pull but on tube it's really irrelevant. Being comfy when your making the weld is more important. It will allow you to make a way better weld regardless of which direction you're welding in.
About cup walking. It's a skill for sure. The basics of it are to rest your cup on the piece at roughly a 45, the angle could vary according to the weldor, and once your arc is started rock the cup to and fro to allow forward movement. Kinda like your opening a door. You could do a YouTube search to see it in action.
Generally tube doesn't require filler wire but once you start to get into schedule pipe, you'll be running filler wire. Which is a whole other game. Even more trickier. I'll post a picture of some welds using filler later this evening.
John I know a little bit about aluminum tank building too. Here's one I built for my Malibu for an overflow tank.
https://static1.pt-content.com/images/pt/2012/08/5936c039-1.jpg
Once again thanks guys.
JEFFTATE
08-24-2012, 08:01 AM
Good welding , I wish I could do that ...
Maybe some day .
Twentyover
08-24-2012, 08:58 AM
Good information. Great input. Thanks for sharing your experience
80proZ
08-24-2012, 01:07 PM
Here's a couple passes I did with filler on a piece of 3/16 SS. Just some scrap.
https://static1.pt-content.com/images/pt/2012/08/486c0464-1.jpg
First pass. I left the wire at the end for no particular reason really!!
Here's a second pass
https://static1.pt-content.com/images/pt/2012/08/246d6d6a-1.jpg
And here they are with all the color brushed out.
https://static1.pt-content.com/images/pt/2012/08/a63f42de-1.jpg
Let's see if this works. I had my youngest son help me make a short little video clip.
http://i1060.photobucket.com/albums/t442/importh8ter/3d564602.mp4
MIKE67
08-28-2012, 07:39 AM
Thanks for the video. I had to copy and paste it in a new window (link didn't work). This gets me motivated to get out in the garage and try this!
09-29-2012, 11:37 PM
bumping for more demo's,
Thanks for the vid....I still can't tig without resting my arms on a base of some sort.
Peter Mc Mahon
09-30-2012, 03:51 AM
Fantastic. Any chance of showing some of us basics in mig welding an exhaust [ one of my next projects ] Thanks!
80proZ
10-02-2012, 05:13 PM
I'll see what I can whip up for you guys!
Indymanjoe
10-02-2012, 05:27 PM
Thanks for the post!
frankv11
10-10-2012, 12:31 PM
Thanks for taking the time, i'm also at that point on my build, 3" exhaust SS will attempt to weld with mig, cause of tools available or get outside help for tig. got Practice on a few scraps and I don't Like it especially the interior ( sugar, bulky ) I will try purging and play with settings.
Question which shielding gas is best I'm using mig .035" 308 wire / stain mix , I'm getting excessive spatter , thinking of trying cO2.
Wow that is the some of the best I have ever seem. DAMM IT !
John Wright
10-11-2012, 10:11 AM
Walking the cup...Jody shows this technique in this video:
http://youtu.be/WSnj8AASuFs
diesel25lrs
10-11-2012, 01:55 PM
Update-Eric thanks for the tips- comfort is definitely key~ I got my exhaust welded up and looks good enough for government work! With this being my first time welding SS tubing, I found that as it quickly heated up after a couple passes I always had to adjust the wire and heat settings.
Frank- What mix are you running? I went with the Higher Helium mix as he told me it would reduce the splatter and it did! I hardly had any- of course you can make it splatter depending on the distance your holding your gun away from weld- just some thoughts.
Coburn_Performance
11-22-2012, 08:57 AM
Just a quick question - when you're welding header tubes, do you use filler wire? I've always had much nicer looking (straw/blue colours) when not using filler and when I add filler the weld look goes black. Would you use more gas?
frankv11
11-22-2012, 01:26 PM
Need to repost properly
Coburn_Performance
11-23-2012, 08:15 AM
I was refering to TIG welding...what do people use for gas flow and filler wire for light gauge (16 ga) 304 stainless tube welding? I wouldn't weld stainless with trimix...wrong chemistry.
frankv11
11-23-2012, 08:21 AM
Just saw this !!! I'm using stain mix argon & carbon dioxide not sure on %'s. my supplier insisted I used this instead of Tri mix , Can you share the percentages if your Tri mix. I manage to get as minimal spatter as possible by adjusting wire speed and distance but it can definitely be better,,
dontlifttoshift
11-23-2012, 11:00 AM
What size filler rod? In my experience if the filler is too big it takes too much heat and that ruins the color. When I use filler for exhaust I use .030" rod.
Fit up is important as well. When trying to fill a gap it also takes more heat and that wil ruin the color.
