View Full Version : watts link
started building a simple watts linkage to see how it changes cornering attributes on my camaro, I will try to make it easily removable for quick testing, here is some quick dirty art
https://static1.pt-content.com/images/pt/2011/02/GEDC1722-1.jpg
brans72
02-01-2011, 04:18 AM
Gonna keep my eye on this one! I like your idea already and maybe some more will chime in when you get further down road. Brandon
Bryce
02-01-2011, 08:09 AM
Rod,
Check out my build thread for a watts link design. I built mine myself. Weighs 8.4 pounds.
Rod,
I looked at that post Bryce, and those are some pretty fancy digital drawings of a watts link!! I used an analog plotter (pencil) myself :twothumbs
basic idea on propeller also still looking at different styles for the cage, but I like the angular V drop that was a second idea
https://static1.pt-content.com/images/pt/2011/02/ctrp_0811_10_zstock_car_dynamicswatts_li-1.jpg
and looking at simplifying the part
https://static1.pt-content.com/images/pt/2011/02/GEDC1703-1.jpg
heres my first part!
https://static1.pt-content.com/images/pt/2011/02/GEDC1693-1.jpg
liquidh8
02-03-2011, 07:54 AM
I'll be watching this, I like DIY! lol, keep the updates coming.
after finally deciding on the shape, I picked up some steel square tube to start with and started by crawling under the car and measuring the frame rails and looking at the mounting area and started with the top bar width, then made a simple center bracket to hold the propeller
https://static1.pt-content.com/images/pt/2011/02/GEDC1689-1.jpg
https://static1.pt-content.com/images/pt/2011/02/GEDC1719-1.jpg
a little more frame work!
https://static1.pt-content.com/images/pt/2011/02/GEDC1720-1.jpg
https://static1.pt-content.com/images/pt/2011/02/GEDC1721-1.jpg
https://static1.pt-content.com/images/pt/2011/02/GEDC17231-1.jpg
GRNOVA
02-06-2011, 07:15 AM
Here Is my Fays2 watts link for some ideas.
I really like the look of that Fays2 watts, have you had any testing with it on and off the car?
basic cage done, I know that I will have to change some of the layout but so far
https://static1.pt-content.com/images/pt/2011/02/GEDC1725-1.jpg
https://static1.pt-content.com/images/pt/2011/02/GEDC17271-1.jpg
https://static1.pt-content.com/images/pt/2011/02/GEDC1726-1.jpg
Flash68
02-11-2011, 11:27 PM
Looks great man.
Bryce
02-11-2011, 11:39 PM
Tim,
You should lengthen your links on your watts link. The bell crank should be closer to 90* to the link at ride height.
GRNOVA
02-12-2011, 03:30 AM
Bryce you are correct that was an old pic (sorry) I was trying to show the frame. I had to order longer rods.https://static1.pt-content.com/images/noimg.gif
Bryce
02-12-2011, 06:50 PM
Cool stuff!
63Duece
04-30-2011, 01:55 PM
hey ROD!
how the Watts link going?????
updates!!???
