View Full Version : Multiplaz, plasma kutter and welder, anyone?
64Chevelle
05-20-2010, 01:10 AM
Hi guys,
stumbled across a device called Multiplaz (http://www.multiplaz.cn/USA/about.asp) while looking for a plasmacutter and welder. The welding process seems like a combination of TIG and Oxy torch technique.
I am starting a pretty big project on my car now and need something to CUT and WELD with. Usually I would be looking at a compressor, MIG welder and plasma cutter (or air driven metal cutter). I've just been using the grinder to cut so far.
I have close to zero welding experience, and to me, this device looks like exactly what I want. I have just done a little MIG welding so far, with mixed results :hammer:
It's a bit expensive at $2000, but it's very economical in use, not to mention a lot less equipment is needed. Add the healthbenefits and all the things I can do with it (cut concrete etc.) it seems like a perfect choice for a DIY'er.
Watch the youtube videos of it's usage. (http://www.youtube.com/results?search_query=multiplaz+eng&aq=f)
I've seen two reviews of it on enthusiast forums and it's gotten great reviews, especially the aluminum cutting/welding seems to be extremely good.
Review in English (http://autorepair.about.com/cs/productreviews/fr/aafpr100403.htm)
The other review I found is in norwegian so I don't care to post it here.
Any opinions?
GrabberGT
05-20-2010, 06:46 AM
Check this one out. Its much cheaper.
http://www.cut-like-plasma.com/
I am not a welder nor have any experience with the above kits but am interested in the opinions of the board.
64Chevelle
05-20-2010, 11:17 AM
Looks like a great low-cost alternative, thanks a lot for telling me. It can't do all the things that the Multiplaz can do, but it can still do a lot of what we car people will need.
fordsbyjay
06-10-2010, 05:47 AM
Well you will still need to buy oxy acy bottles and regulators so you will be close to a grand when you are done. I have one and I don't know how many hours of practice it takes to get as good as the videos but am no where near that level. I would highly recommend just buying a plasma cutter because the learning curve it 1000X faster than the Henrob torch. Trust me, I learned the hard way.
coolwelder62
07-08-2010, 05:50 PM
Over on www. lateral-g.net mizfit has a brand new in the box plasma cutter from northern tool for 650.00 shipped.check it out.
Happyfunballs
07-09-2010, 04:02 AM
It's posted here as well. (https://www.pro-touring.com/forum/showthread.php?t=70288)
