View Full Version : Tig conversion kit?
Mike Davis
03-08-2010, 07:53 PM
I have a lincoln 200 arc welder, can i get a tig conversion kit for it? I understand it will probably be a scratch start, but i would like to do 1/4 to 3/8 aluminum. Also some mild stainless would be nice.
toxicz28
03-09-2010, 01:49 AM
They sell tig torches that you can clamp a stinger handle on, attach a gas hose, etc. and weld with. Mild and stainless steels aren't a problem, make sure your torch is - and the ground is +. The question is "Does the machine weld AC? If not, you can forget about welding aluminum.
wendell
03-09-2010, 06:22 AM
Pretty much isn't going to work. With out HF and AC balance control, you're not going to be able to weld AL.
Mathius
03-12-2010, 01:20 PM
If he's talking about those little 220amp buzz boxes that are sold at home depot, lowes, etc. they're ac only to begin with. You can grab them on craigslist for about $100 regularly used.
But can't you weld aluminum with DC+ ? I thought I had heard that, but I've never tried to tig aluminum with anything besides ac and I haven't done that in about 4 years, so I can't confirm it.
Then again, if memory serves, high frequency is what starts the arc prior to touching the material if you're not using a foot pedal and I don't know how you could scratch start aluminum? It's too susceptible to contamination. The tungsten burns at a much higher temperature than aluminum and contaminates the weld from the word "go."
Mathius
80proZ
03-12-2010, 03:31 PM
Mathius
You can weld AL on DC+ but it runs really hot.You can also scratch start it but you wont like it.The HF does more than just start your arc.
IF its a AC only machine you will not be able to TIG steel or SS.
