View Full Version : bumpers
hag6888
10-28-2012, 10:23 PM
I'm fabing up bumpers for my 67 Chevy c10. Any pics out ther. Or ideas ? What tools to use?
raustinss
10-31-2012, 06:08 PM
You need to explain a little more as to what look you want...stock cut up moved in closer to the body...full smooth custom...off road fab four style
hag6888
11-27-2012, 11:50 PM
I want them tucked in smoothed less over hand on the sides
jlcustomz
11-28-2012, 12:44 PM
What you're describing is generally referred to as tucking. Google tucked steel bumpers. One of the most commom methods of doing this involves marking the bumpers a few inches from the end,cutting out a strip ,& welding with mig or tig & resmoothing. I generally use masking tape to mark my area to remove, cut with a 4 1/2" grinder with a thin cutoff wheel & temporarily reattach ends with duct tape(regular Gorilla brand or aluminum) to recheck fit before welding.
Being that you asked what tools to use tells me you probably don't know much on metal fabricating. You could possibly cut & fit the ends & have someone weld them if you can't. Hope this helps.
http://www.google.com/webhp?hl=en&tab=iw#hl=en&sugexp=les%3B&gs_nf=3&gs_mss=Tucked st&cp=20&gs_id=27&xhr=t&q=Tucked steel bumpers&pf=p&tbo=d&sclient=psy-ab&oq=Tucked+steel+bumpers&gs_l=&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=84f5e54452ebb3b9&bpcl=38897761&biw=1920&bih=954
astroracer
11-28-2012, 04:55 PM
I built this one for my '95 Sierra. Started with a raw bumper and built the rest out of muffler tubing and 10ga steel :)
https://static1.pt-content.com/images/pt/2012/11/MVC010Fvi-2.jpg
https://static1.pt-content.com/images/pt/2012/11/MVC009Fvi-6.jpg
Here are a few of the construction.
https://static1.pt-content.com/images/pt/2012/11/phpattachmentid4555d1079028278vi-1.jpg
https://static1.pt-content.com/images/pt/2012/11/phpattachmentid4554d1079028231vi-1.jpg
I spent about 3 months just doodling designs and working through ideas. I built the drivers side out of posterboard and used that for the left and right hand patterns.
Mark
hag6888
12-27-2012, 07:09 PM
Thanks guys that was some good knowledge there
