View Full Version : Crossmember Fabrication
old66tiger
04-01-2010, 03:29 AM
My New headers on my GTO may hit the factory crossmember and I am looking for options. I was going to make a new crossmember out of 1" square tubing, but I am not sure if that will be strong enough. Thoughts?
doghouse
04-01-2010, 07:43 AM
you would need to gussett any stressed areas,
minumum .125 wall, think of the stess this handles.
The WidowMaker
04-03-2010, 07:00 PM
could you just cut some out of the factory piece to make it work, or is it going to remove too much?
LSx_88_Ciera
04-03-2010, 07:09 PM
Vintage GTO or Monaro?
Dstoltenberg
09-15-2010, 02:52 PM
Ever think about getting some chromoly tubing and bending one to fit your needs? Popular Hot Rodding did one on their project Laguna in an article awhile ago, very simple and came out very nice. As soon as I get the engine and trans mocked up in my car i'll be doing the same thing.
67zo6Camaro
09-15-2010, 05:42 PM
Many options depending on your skill set and/or tools...or just how big your pocket book is. Send some pictures. If you need just a small amout of room then scalloping a small curve out will do. Then welding a shaped patch back in with similar wall thinckness is typically how it is done. If your looking for something more ellaborate let me know and I can get you directed in the correct direction.
Brett,,,Campbell Customs metal fabrication.
PhillipM
10-05-2010, 03:45 PM
While Chromoly is definitely overkill for this part on most vehicles, standard 1.75" .120 wall DOM would be plenty strong and easy to work with if you have the right tools. Many times I just cut the factory one apart and make it fit. Then weld it all up and paint.
10-06-2010, 08:22 PM
good points Phillip
anyone make an aluminum one?
