View Full Version : Engine Miscellaneous
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14
  1. What gasket material for a fuel pump top ring?? (1 replies)
  2. Why does BluePrint Engines say to not go synthetic until 9000 miles?? (0 replies)
  3. Source for Tall Carbon Fiber Dry Sump LS Valve Covers (0 replies)
  4. GM 632 crate engine??? (0 replies)
  5. CT525 Oil Gallery Barbell (0 replies)
  6. MSD Atomic AirForce Height (0 replies)
  7. Goodyear Accu-Link Belt (2 replies)
  8. Holley 20-242 mid-mount accessory drive for BBC? (1 replies)
  9. Converting from linkage to cable actuated throttle? (0 replies)
  10. Suggestions on LS3 Belt Squeal (6 replies)
  11. Ford boys, fuel tank questions (7 replies)
  12. WTF is in my oil pan? (1 replies)
  13. Am I ok to machine my intake so my valve covers fit? (2 replies)
  14. Replace lifter on BBC without removing intake (3 replies)
  15. BBC in a Pro tourer? (25 replies)
  16. 434 SBC Build (4 replies)
  17. Double hump head question (0 replies)
  18. BBC builder in WA state? (0 replies)
  19. Engine Core Fee...LT1 6.2 Gen V engine. (3 replies)
  20. LT4 Rocker arm issues (0 replies)
  21. Removing LS3 from second gen Camaro (0 replies)
  22. Rear main seal trouble (0 replies)
  23. Wild looking custom engines (1 replies)
  24. LS-LT combo engine question (3 replies)
  25. The dreaded one piece rear main seal (0 replies)
  26. Lsa supercharger vs procharger (2 replies)
  27. How to choose correct size balancer for solid lifter 327 (2 replies)
  28. 2019 lt BALANCER PULLER ? (0 replies)
  29. What is the origin of maximum piston speed of 4,000 ft./min rpm limit? (3 replies)
  30. What size rocker studs do I need? (4 replies)
  31. Can anyone identify this engine? (5 replies)
  32. Gm 502 crate engine question(s). (3 replies)
  33. AutoX Oil Pan (2 replies)
  34. 454 LSX Runway Racer (0 replies)
  35. Camaro or fox body running motor (0 replies)
  36. Motor Mounts (4 replies)
  37. Gen 6 GM Small Block (1 replies)
  38. Dry Sump install in First Gen with stock subframe and gen 1 SBC (0 replies)
  39. Brodix cast iron engine blocks? (0 replies)
  40. Ever heard of a torque spec for distributors? (3 replies)
  41. SBC 383, Piston to Valve clearance (0 replies)
  42. Vegas Machine/Nevada Crankshaft of LV good? (0 replies)
  43. West Coast aluminum ls block needed for mockup (0 replies)
  44. Wegner Accessory Drive (2 replies)
  45. 302 Windsor Build Pre-planning (12 replies)
  46. Skipwhite engine 434 sbc (2 replies)
  47. Question on Melling verse GM pick-up tube O-ring (1 replies)
  48. SBC Power Steering Pump mounting bracket question (5 replies)
  49. Need help establishing an engine value (0 replies)
  50. Brownfield heads, "60/40" offset, and roller rockers without needles. Help! (3 replies)
  51. Important question on solid lifter adjustment (1 replies)
  52. Catch can. (15 replies)
  53. Wanted- Ford modular 4.6 crankshaft flange bolt circle diameter (0 replies)
  54. Summit 8708 cam (13 replies)
  55. 73 Firebird trunk mounted fuel cell (1 replies)
  56. Recommend a PT/RR baffled wet sump SBC oil pan with crank scraper for 327? (2 replies)
  57. Progression Ignition distributor Real deal or real waste of money? (4 replies)
  58. Driver’s Side Alternator Bracket (1 replies)
  59. ls3 engine mounts (4 replies)
  60. Throttle body size question (7 replies)
  61. How would build a sbc 400 ? heads, cam ect (5 replies)
  62. chevy 400 sbc 2 bolt main? (8 replies)
  63. Actually,,-7 (0 replies)
  64. Roller cam repair / regrind? Btr stg ii ls3 n/a grind (2 replies)
  65. Sniper efi (10 replies)
  66. Anyone running Jones Racing accessories on a street car? (0 replies)
  67. Old Timey Stroker (5 replies)
  68. SBC gasket help (3 replies)
  69. using oil (5 replies)
  70. Break in oil question (1 replies)
  71. KRE High Port Heads Second Gen Trans Am (4 replies)
  72. Help with 502 timing specs (2 replies)
  73. Will there be an EV section on this forum soon? (3 replies)
  74. LS427/570 injector specs... (10 replies)
  75. Windage tray modification? (3 replies)
  76. Broken tap (7 replies)
  77. BTR LS3 STG2 N/A CAM for 408 lq9 / supercharger? (0 replies)
  78. Leak Down Test on SBC (2 replies)
  79. 416 Forged TVS2300 Build recommendations (20 replies)
  80. Chevy 396 (2 replies)
  81. Race Tec Pistons (3 replies)
  82. LQ4 Spun Cam Bearing (7 replies)
  83. engine, cam choice. (0 replies)
  84. Powermaster Starter (9 replies)
  85. Engines direct from Chevrolet or authorized distributors? (4 replies)
  86. Accessory drive recommendations? (27 replies)
  87. LS Head Gasket / Compression Help (0 replies)
  88. Fuel pump fuse gets hot (5 replies)
  89. Good Cam Choice? (0 replies)
  90. Howard's Composite Fuel Pump Rod (2 replies)
  91. lsa Blower on LS1 (9 replies)
  92. Big Block in Falcon (3 replies)
  93. Down Shifting Problem (0 replies)
  94. ford302 (1 replies)
  95. Cam selection help – Is there a near stock no compromise option? (7 replies)
  96. Bolt-on PS Tank or Remote Reservoir? (11 replies)
  97. Some help please... (2 replies)
  98. Performance shop near OC-LB California (0 replies)
  99. LSA install (3 replies)
  100. Filter for Moroso vac pump regulator? (0 replies)
  101. Dry Sump reservoir Caps? (2 replies)
  102. 427 BBC with Moroso 20460 8 quart pan (0 replies)
  103. Pro-Classic or Ultra Pro? (6 replies)
  104. new rocker arms/ pushrods (1 replies)
  105. L92 cam recommendation (10 replies)
  106. Dipstick side swap? (2 replies)
  107. Serpentine swap help needed (5 replies)
  108. Starting a fresh engine from 2 year storage lube question (0 replies)
  109. Starting a fresh engine from 2 year storage lube question (0 replies)
  110. One clean spark plug (5 replies)
  111. Which Heads (2 replies)
  112. Help me ID these engine frame brackets - 69 Impala (3 replies)
  113. LSA Accessory Drive Help (4 replies)
  114. LS blocks (7 replies)
  115. 5.3 vortex (lm7) (2 replies)
  116. 347 Stroker suppliers? (0 replies)
  117. Preferred LS spark plugs? (3 replies)
  118. Compression height and rod length (2 replies)
  119. LS offset? (8 replies)
  120. AFR head corrosion question (6 replies)
  121. stock dipstick tube with Milodon pan? (1 replies)
  122. Frame mounts (6 replies)
  123. DSE subframe what oil pan with stroker motor (2 replies)
  124. Need help choosing the right cam (2 replies)
  125. ATK Engine Problems (13 replies)
  126. School me on a good fuel system (8 replies)
  127. Best/strongest SBF motor mounts? (5 replies)
  128. LS swap oil pans... (23 replies)
  129. LS2 Is Dieseling???? (0 replies)
  130. Any do exhaust wrap + cermaic coating? (6 replies)
  131. Ls-700r4 (1 replies)
  132. L94 block Cracked!! Can this be fixed? (1 replies)
  133. Ls block can this be fixed? (8 replies)
  134. Engine sourcing feedback... (0 replies)
  135. From blowing oil pan gasket to now blowing dipstick tube - help (27 replies)
  136. Can Earl Fittings be used on Russell Hose (7 replies)
  137. Serpentine Moves forward on A/C compressor pulley (3 replies)
  138. Intake Piping - Rattle Can Ceramic/Thermal Barrier? (6 replies)
  139. Camaro C&R radiator users. (0 replies)
  140. Serpentine conversion question (6 replies)
  141. BTR LS2 STG2 CAM running in a LS3? (2 replies)
  142. LQ4, LQ9,LS2,3,6,7 Realistic builds 500 rear wheel HP (9 replies)
  143. aluminum head options for 461 stroker to get to 650hp Pontiac 400 block (24 replies)
  144. Name that cam (3 replies)
  145. Accusump and check valve (5 replies)
  146. Gen V LT4 question **HELP** (3 replies)
  147. Double check me on my oil cooling setup (16 replies)
  148. Question on cowl induction for 60's era Chevy (0 replies)
  149. Autocross Oil Pan (13 replies)
  150. 2 piece mini starter (2 replies)
  151. Cam for ls3 (11 replies)
  152. Advice for storing my car (6 replies)
  153. Billet Specialties V-Trac Pulley System (0 replies)
  154. 408 CID LS Build 4.25" Stroke - Oil Pan Issues - Detroit Speed Subframe (2 replies)
  155. Big Block Chevy-Water pump has no heater or by-pass outlets... (3 replies)
  156. Oldsmobile Engine Power Steering Pump Solutions - What have other people tried? (1 replies)
  157. 69 camaro with zl1 aluminum 427bb (0 replies)
  158. 1971 Camaro engine mounts... LS swap (2 replies)
  159. Help me build a better pcv system (19 replies)
  160. ARP Bolt Torque Specs (4 replies)
  161. msd ls ignition map port to gm map sensor (1 replies)
  162. Any vendors running Detroit Speed deals? (9 replies)
  163. Midgrade Gas and twin turbos ... (6 replies)
  164. Pankl connecting rod (6 replies)
  165. Bronze dist gear and valve guides impacting used oil analysis numbers? Or bearings... (1 replies)
  166. Need help selecting cam for my setup. (3 replies)
  167. 1969 Mustang 392 stroker combo (0 replies)
  168. 6.0 LS Build (70 replies)
  169. LS type intakes (2 replies)
  170. Breaking aluminum rocker arms (5 replies)
  171. adjusting hydraulic roller cam (1 replies)
  172. LS Swap Question (8 replies)
  173. Engine monts.. sb vs bb (1 replies)
  174. Gen 1 SBC oiling problem. (9 replies)
  175. 69 Camaro Gen V LT4 Converions? (1 replies)
  176. Help identifying engine (2 replies)
  177. Too much vacuum (9 replies)
  178. Merlin Engines.. HELP!!!!!! (2 replies)
  179. PCV Valve Baffle (4 replies)
  180. When to put synthetic oil in a fresh engine (???) (3 replies)
  181. coyote swap 1969 mustang (3 replies)
  182. Can lifters go bad? Need advice (21 replies)
  183. New 5.7 Hemi swap into a 70 challenger help wanted... (5 replies)
  184. Pontiac 1973 Trans Am HP to the wheels on dyno to compare to improved 455 rebuild (9 replies)
  185. Mopar Experts: Opinions Needed On Engine/Trans Choice (3 replies)
  186. Turnkey engines (0 replies)
  187. SBC/Brownfield heads, Why intake valves .100 longer than exhaust? (2 replies)
  188. AEM Dry Air Filters versus others ? (1 replies)
  189. Accusump one way valve question (6 replies)
  190. Light 327 11-1 Forged Pistons? (4 replies)
  191. Giant LS3 Intake manifold Dyno shoot out (7 replies)
  192. Help me pick a Autocross cam for my LS1/t56 70 Camaro build please (2 replies)
  193. will this cause my fuel pump to die an early death (3 replies)
  194. Amsoil oil is right for me (1 replies)
  195. Moroso oil pan bolt issue? (0 replies)
  196. aluminum head screw up drilling broken stud (5 replies)
  197. GM Type II Pump Whine - Any Magic Remedies? (4 replies)
  198. Powdery white crust on Aluminum block (11 replies)
  199. Aerospace Vacuum Pump with Alternator, Power Steering Pump and Electric Water Pump (2 replies)
  200. Pinto -- Move engine back or front wheels forward (10 replies)
  201. Ground clearance to oil pan and bellhousing- Third Gen Nova (2 replies)
  202. Engine combination, help needed (3 replies)
  203. Engine Vacuum (1 replies)
  204. Radical SR8 casting flaw oil leak (26 replies)
  205. throwing oil out oil pan (4 replies)
  206. Custom OTR (2 replies)
  207. Video Billet Specialties LS Tru Trac Installation (0 replies)
  208. Can I match a Pontiac 455 with a Chevy BW Super T10 four speed (4 replies)
  209. air cleaner for 68 camaro cowl hood (4 replies)
  210. 428/455 into a 69 bird (0 replies)
  211. Poly Loc Fail - Schumacher (2 replies)
  212. 2017 Gen V LT1 with 8sp harness and fuel questions (1 replies)
  213. Chevrolet engine question.. (15 replies)
  214. -12 tube oil breather (1 replies)
  215. litre's gallons per hour (8 replies)
  216. LS Engine learning curve is steep! (5 replies)
  217. Don Hardy Race Engine LS 427 with Billet Specialties Tru Trac Serpentine System (3 replies)
  218. LS Valve Cover Adapter (0 replies)
  219. Billet Specialties Tru-Trac Installation SBC (0 replies)
  220. Power Steering Pulley Installer (3 replies)
  221. short block pontiac (19 replies)
  222. Cleaning Oxidation off a Aluminum Block (3 replies)
  223. Help with engine decipher.... please (0 replies)
  224. Gen VI 454 stock piston weight (0 replies)
  225. LS Chevrolet Script Billet Valve Covers (1 replies)
  226. Show me your Accusump installation! (16 replies)
  227. Accusump custom cut-on switch (1 replies)
  228. Getting the fuel from the inside to the outside of the frame rail (0 replies)
  229. Camshaft problems.. 327chevy (0 replies)
  230. Old School Ford 5.0 EFI (1 replies)
  231. Crane Anti pump lifters or Comp high energy? (0 replies)
  232. First time engine start, run and vibration. (8 replies)
  233. Cross ram injection for LS engines. (0 replies)
  234. So been working on a rod/piston combo for my 3800 Buick engine,,,, (0 replies)
  235. Decided to fix my 327, but wich cam for it? (16 replies)
  236. Need some tuning help, '94 Astro with an LT1 (16 replies)
  237. Mock up / replica / foam engine for Ford 5.0L Coyote? (0 replies)
  238. possible intake sucking oil? (4 replies)
  239. Are these 461 or 461x heads? (2 replies)
  240. Which camshaft to a 350 with 461 heads (3 replies)
  241. Black Mountain precision 2" front drives (12 replies)
  242. Crankcase evac system, mufflers? (7 replies)
  243. type 2 ps pump, techs chime in (1 replies)
  244. Looking for a good engine builder in the south (0 replies)
  245. Oil pan oil cooler adapter bypass with sensor fitting help (LT4) (2 replies)
  246. buick 455 serpentine kits (1 replies)
  247. Checking push rod lenth with plastic proform push rod lenth checker (10 replies)
  248. Type 2 power steering pump (2 replies)
  249. Need some strong pushrods (3 replies)
  250. 60 degrees of initial advance?? (2 replies)
