View Full Version : LS swap oil pans...
Snowcatter
10-16-2019, 07:14 AM
Looking for opinions and expertise on oil pans. I'm using the AME GT Sport front clip in a 69 Camaro and installing a 2013 ZL1 LSA. Stock oil pan definitely isn't going to fit and my question is between the Chevrolet performance pan and the Holley variants is there any issues with the GM pan? It is $100 cheaper than the Holley ones. Is it worth spending the extra Benjamin on the Holley?
dontlifttoshift
10-16-2019, 08:18 AM
The GM swap pan is great if you prefer the oil pan to be the first part of your car that drags on the ground.
dhutton
10-16-2019, 09:03 AM
the gm swap pan is great if you prefer the oil pan to be the first part of your car that drags on the ground.
lol...
Snowcatter
10-16-2019, 09:23 AM
The GM swap pan is great if you prefer the oil pan to be the first part of your car that drags on the ground.That is a good point...I suppose I'm going to need to remove the pan and set the motor in place to determine the max depth the pan can be before extending past the crossmember....
Gmachine1911
10-16-2019, 02:50 PM
Four words...Mast Motorsports oil pan.
More ground clearance then Holley.
dontlifttoshift
10-16-2019, 03:15 PM
Care to back that up? With actual measurements?
168373
https://static1.pt-content.com/images/pt/2019/10/Oil_Pan_Dimensions_1024x1024-1.jpg?v=1560974278
There are some things that the Mast pan does better but I prefer the Holley pan with the bellhousing mounts built in and the ability to use the Earls thermostat for the oil cooler.
Snowcatter
10-16-2019, 04:14 PM
Does the stock ZL1 LSA oil cooler work with the Holley pan?
Gmachine1911
10-16-2019, 04:45 PM
168373
No, I don’t mind backing that up at all...and btw, the Mast pan also has oil cooler provisions built in. 168397
Snowcatter
10-16-2019, 04:47 PM
More ground clearance then Holley.That pan is even more expensive than the Holley...what makes it worth a $100 more?
dontlifttoshift
10-17-2019, 04:42 AM
Not sure why this didn't post before. But 5.75" is more than 5.69" It is entirely possible that someone fibbed on their dimensions but I would say they are close enough to be a wash. I am aware of the provisions for the oil cooler on the Mast pan but that doesn't address the thermostat.
68Formula
10-17-2019, 02:12 PM
5.75" is more than 5.69" https://static1.pt-content.com/images/pt/2019/10/Oil_Pan_Dimensions_1024x1024-1.jpg?v=1560974278
168418
And it looks like they're just comparing Mast to the Holley 302-1. But the 302-2 has more ground clearance by 0.29". Whether or not that matters, I don't know.
andrewb70
10-18-2019, 08:09 AM
What pan does AME recommend with their front clip? Shouldn't they know what works best?
Snowcatter
10-18-2019, 08:55 AM
AndrewFrom AME installation instructions:
Oil Pan Selection
The engine oil pan design is critical for proper performance as well as trouble-
free installation. The location of the steering rack only allows the use of oil pans
that replicate the stock profile under the number one and two cylinders. The use
of fabricated aluminum or a highly modified pan may cause interference and
require notching for proper fit.
The F-Body LS oil pan has been tested and approved for sufficient clearance;
GTO, Corvette and truck pans utilize similar front profiles but should be test-fitted
prior to final installation. C5 “batwing” pans should be avoided as they will
interfere with headers.
They mention the F-body LS pan but I'm not sure which pan specifically they are referring to????
silo84
10-18-2019, 09:42 AM
typically the "F body ls pan" refers to gen 4 LS pan 98-02
andrewb70
10-18-2019, 10:13 AM
I would agree with the above statement. The Holley 302-2 and 302-3 pans offer even more clearance in the rack area than a 4th gen F-body pan and have a slightly shorter (lengthwise) sump, so they should work very well for you. The Holley 302-3 offers clearance for a stroker crank and also has two, cast ports for turbo drains, in case that is something of a consideration for the future.
Snowcatter
10-18-2019, 05:14 PM
Thanks everyone for your help...I am leaning towards the Holley 302-1 because the sump is much more rearward and my initial fitment of the motor appears that the 302-2 profile will hit the crossmember. I will definitely be posting pictures of it for future reference once I get it installed. I do want to look into that F-body pan as well to compare the profiles.
Snowcatter
10-30-2019, 08:33 AM
So after comparing all the LS oil pan options available from Holley, Mast and GM I discovered that the LSA engine I the Cadillac CTS-V has a profile very close to the F-body pan plus it has the mounting provisions for the oil cooler which make this an obvious winner for my application. Also it is much cheaper than the Holley ones. I can order the pan, dipstick and tube, pickup tube, and gasket for less than just the Holley pan. I am ordering this now and will post pictures of the fitment as soon as I get it installed.168715
andrewb70
10-30-2019, 08:35 AM
It's deeper than the f body pan. Ten bucks says it will hang below the front cross member. I wouldn't be comfortable with that.
Snowcatter
10-30-2019, 08:47 AM
It is 1" deeper and I think I can live with that. It's the oil cooler mounting that is the main reason to go with this pan. Most LS engines don't have the engine mounted oil cooler which is only on LS3 & LSA engines.
andrewb70
10-30-2019, 08:59 AM
Will the oil cooler fit in the chassis and with the headers you're using?
dontlifttoshift
10-30-2019, 09:34 AM
I have the holley pan in my stock subframed 2nd gen with their mounts.
The boss for the drain plug is ground flat from dragging the pavement on occasion, it just barely hangs below the crossmember.
Have you talked to Morrison to see what pan they reccomend?
dhutton
10-30-2019, 04:02 PM
I used the CTS-V pan with my Art Morrison subframe. I vaguely recall massaging things a little but some of that was due to the alternator on the stock accessory drive. Pretty sure the pan hit the rack lines that cross over.
Don
Snowcatter
11-23-2019, 09:17 AM
Ok I got the CTS-V pan installed and it fits in there with plenty of room all around and only hangs 1/2-3/4" below the crossmember. I can live with that plus it eliminated the DOD pressure bypass valve in the pan allowing for more oil pressure and provisions for mounting the LSA/LS3 oil cooler. I will most likely be building a windage tray that will protect everything under there anyway and provide less wind drag. Tried to take pictures and failed...poor lighting. I will try again next time I'm home.
68Formula
11-29-2019, 05:33 PM
A little late, but the Mast includes a baffle kit. Holley you have to buy it separately (and they're pretty expensive - $200+).
