View Full Version : Chevy 396
elwaupo
01-04-2021, 05:49 AM
I have a 69 SS Camaro with a small block that I installed a Sniper EFI with a 700R4. I’m having a 12 bolt built for it and I have a chance to get a numbers matching 396 for a 69 Camaro at a dirt cheap price. My question is:is the 396 worth buying as it’s the 325hp version?
I know the big hype is the 454 but can the 396 be built to push 375-400hp without a lot of money?
Lonnies Performance
01-04-2021, 09:58 AM
400hp should be possible with just a cam & intake.
If your trans in slightly built, you could bolt this up to your 700R4 & put your EFI on it.
You will need headers, motor/frame mounts & cross member, plus the big block heater core for valve cover clearance.
As for the numbers matching, it matches someone elses car, not yours, so I would recommend posting the engine VIN on
https://www.camaros.net/ to see if the original car still exists.... you may pick up enough money to resell it & get a good start on your 454.
elwaupo
01-04-2021, 12:35 PM
Thx, I’m still thinking about it as I could just install a 383 and not change much other then the proper stahl converter and harmonic balancer. I have a Vintage AC so the firewall is clear.
