View Full Version : Motor Mounts
elwaupo
01-26-2023, 10:19 AM
Should motor mounts be replaced over time? I have a 69 Camaro with stock motor mounts I installed probably 25+ years ago, if so should I go with stock or the polyurethane mounts?
Pro Touring Store
01-26-2023, 11:22 AM
Over time, rubber will crack. I would inspect the ones you have & if they're cracked you should replace them.
I like poly mounts myself.. The rubber ones are fine for stock engines or daily drivers. Poly holds up more especially if you have higher torque and/or traction.
-Dale
I installed some poly mounts recently from Summit and they worked well. I did it when I was replacing the engine. One tip for you if you decide to do it. Drill out the holes a tad bit larger so you don't have to wrestle with them for several hours like I did.
Below are the ones I installed:
https://www.summitracing.com/parts/ens-3-1114r/make/chevrolet/model/camaro/year/1969
elwaupo
01-28-2023, 08:52 AM
Is there a difference in vibration with those motor mounts?, I know urethane is stiffer
Everything is nice and tight, no motor movement or vibration that I can see.
