GoodysGotaCuda
01-16-2018, 02:38 AM
I have a Speedway Motors Type II GM pump on my Hemi. It moves the tires fine, but despite my best efforts, I cannot get rid of the pump whine.
I have about 1,500 miles on it
The fluid in the reservoir does not appear aerated
I have an inline filter on the return side
Fluid level is correct
Borgeson steering box
Running Dexron ATF
Any suggestions? I have thought of adding a fitting to the cap and forcing a higher fluid level to see if I can help purge more air out. I've noticed the fluid level is lower than the highest point in the pressure line, but some OEM applications are also that way. It's not the whine of a dying pump that you hear from across the parking lot, but it does not sound right.
147956
Running Dexron ATF
147956
