View Full Version : ARP Bolt Torque Specs
badazz81z28
12-20-2018, 06:51 PM
When you all swap out stock hardware for ARP hardware on LS aluminum blocks, do you use the ARP general torque specs or GM stock specs? I know the torque is to acheive proper stretch of the fastener, but seems ARP specs are very high.
andrewb70
12-20-2018, 08:57 PM
Which hardware are you talking about, exactly?
badazz81z28
12-22-2018, 08:32 AM
Bolts like the LS water pump. The instructions say to see their generic specs.,
andrewb70
12-22-2018, 08:46 AM
I would use the GM specs and make sure to use antisleeze....as I recall the water pump bolts are 8mm? Don't need a lot of torque.
Sinnister69
04-30-2020, 04:20 AM
Waterpump bolt specs are 11lbft first pass then 22lbft final pass
