View Full Version : Which Heads
elwaupo
04-16-2020, 05:13 PM
Ok I know this question has been ask many times and I’m going to ask again. I have a 69 Camaro with a 350/700R4, Crane cam (like the old RV type), Holley Sniper, headers. I’m happy with its performance especially since I installed the Sniper but I want more power, my question is which aluminum head would work best? Would it be advisable to change out my cam to? I’d like to shoot for a 350+HP range.
I know there are many different manufacturers out there and any advice would be appreciated.
68Formula
04-19-2020, 07:20 PM
AFR makes some great heads with very efficient ports. For your displacement go with the smaller intake runner volume likes the 195cc Street Heads. Coupled with Lunati Voodoo 219/227 @ 0.050" Lift, .515/.530 lift (assuming you can use hydraulic rollers) should easily make your goal.
elwaupo
04-20-2020, 04:55 AM
That sounds like a good combination. I’ve been trying to make sure of the correct runner size for the heads, in the past it seemed everybody wanted to run a 2.02 head but a mechanic friend of mine warned me about running to much air-flow without the right cam. I don’t want to run just any brand but a brand that will work correctly. Thanks for your advice.
