View Full Version : Sniper efi
5spd540
08-01-2021, 08:08 AM
I was looking at doing a sniper EFI on one of my cars but wanted some input. What fuel pump are you using and is it a in take or mounted on a frame rail or something. I was looking at doing the external pump but was wondering how loud it would be like that. Any input appreciated
Jk918
08-02-2021, 01:35 AM
Alot use an in tank pump from the likes of Tanks inc, holley etc. I am using a new ZL1 fuel pump with vaporworx control which eliminates the return line.
Tsaints1115
08-02-2021, 05:35 AM
Go with an in-tank from the start.
andrewb70
08-02-2021, 06:12 AM
In-tank pump is the way to go. If you want the best, consider going with Vaporworx. The modern fuel modules are better than the old "pump on a stick."
Also, instead of the Sniper system, I would consider the Terminator X Stealth.
https://www.holley.com/products/fuel_systems/fuel_injection/terminator_x/terminator_x_and_x_max_stealth_4150/
5spd540
08-02-2021, 02:20 PM
i am looking at a 2 barrel system. No use for the 4 barrel system
andrewb70
08-02-2021, 03:51 PM
Gotcha. The the Sniper is your only option. What kind of car and engine?
5spd540
08-03-2021, 10:21 PM
Plan to put it on a online 6 for my c10 truck. I also want to do one in my pro street look alike car but not sold on that yet.
andrewb70
08-04-2021, 04:30 AM
I've tuned a 4 barrel Sniper on a 250 online 6. Ran pretty good.
5spd540
08-06-2021, 05:15 AM
I had a 4 barrel set up and sold it decided not to use it.
Interceptor5588
08-06-2021, 05:35 AM
Ideally you should get a new EFI style tank and pump. Without an EFI sump you get fuel starvation in corners at anything under 1/2 tank.
Tsaints1115
08-06-2021, 07:53 AM
Holley has a retrofit in tank pump equipped with their hydra-mat which takes care of that issue.
