View Full Version : msd ls ignition map port to gm map sensor
sean69cam
12-12-2018, 10:00 PM
Going through a ls swap. Using the MSD ls ignition controller(6014). Trying to figure out how to adapt the 1/4" camozzi fitting on the side of box to my gm map sensor on the intake manifold. Basically the camozzi fitting allows a tube to insert. I am debating if should even try to connect, since no plans for forced induction
sean69cam
12-13-2018, 10:55 AM
Maybe the mad box has its own map sensor inside. vacuum hose to intake manifold instead of electric map sensor at manifold
