View Full Version : Can anyone identify this engine?
dap03
06-19-2023, 03:51 PM
Bought at an estate auction for $20. Still have to go pick it up. 207981207982
dap03
06-19-2023, 04:04 PM
Things that might be important to consider:
-rear mounted distributor
-recessed timing chain
-oil filter on high rear passenger side
-flat across bottom of timing cover
ZZ430
06-19-2023, 06:01 PM
Yeah, it's a Caddy 4100.
It was mounted in a transverse location, that's why the oil filter is at the rear.
I worked at the dealer back in the day.
Boat anchor material.
dap03
06-19-2023, 07:31 PM
Wow thanks! From the wiki it looks like they were pretty terrible.
ZZ430
06-19-2023, 09:08 PM
I can't even guess how many I worked on. You name it...it went bad.
Overheating and main bearing knocks were normal routine.
topperred
07-11-2023, 07:58 AM
Caddy 4100. The Caddy 400 boasts a formidable engine that delivers unparalleled power and performance. Its robust motor is specifically designed to tackle challenging terrains, ensuring you never face any hurdles during your off-road adventures. Whether you're cruising through rocky landscapes or traversing steep slopes, the Caddy 400's exceptional power and torque will effortlessly conquer any obstacle in its path.
