View Full Version : Type 2 power steering pump
KEV 190164
04-04-2017, 10:10 AM
hello all. I have a 79 trans am fitted with a modified buick 455 around 550hp . I have a hydraboost kit to fit also have a 670 steering box I have the standard type gm power steering pump . would I be better of fitting the type 2 and can I still fit my hydraboost to it. if so which type 2 would be the best. cheers kev
sam 74
04-04-2017, 03:55 PM
your saginaw pump will work fine, probably even better than most type 2 pumps. if you're set on useing a type 2 pump talk to hydratech, they'll tell you the requirements you'll need out of the pump, on my type 2 i had to increase the pressure so it would operate both the brakes and the steering.
garvir
04-04-2017, 04:10 PM
here is a great company for steering info, go to turnonesteering.com or call 989 759 4209.. i did a thread on 3/21/17 in the suspension part about turn one, BRET the president of RIDE TECH sent a comment about they use turn one in there race cars, not cheap but the best. RAMEY from UMI turned me on to turn one four years ago, they use turn one for the green machine. turn one rebuilt my steering box in my 88 monte carlo, i bought from CPP, junk never worked right, turn one made it right. these guys know the proper valving for your pump and steering boxes.. turn one 989 759 4206....saginaw, mi...THEY HAVE DYNOS FOR TESTING THERE STUFF, I NEVER KNEW THERE WERE DYNOS FOR TESTING STEERING PUMPS AND RACKS.
