View Full Version : Fuel Injection
Pages : 1 2 3 4 [5] 6 7
  1. How to choose fuel rails? (2 replies)
  2. Fuel Line Mounting Brackets?!?!?! (0 replies)
  3. Need to find Edelbrock part or replacement. (0 replies)
  4. FAST XFI and Dual Sync, Frank S are you around? (6 replies)
  5. O2 sensor placement for Gen 7 DFI (3 replies)
  6. MAF on turbocharged engine (2 replies)
  7. Rock Valley tanks at the track (3 replies)
  8. external anti-surge tank with A1000 (8 replies)
  9. Fuel Tank Advice..Stock tank with EFI setup? (19 replies)
  10. EFI Six-Pack - F&B ? (3 replies)
  11. sheet metal intakes and ITB's for SBC? (7 replies)
  12. 502 Ram Jet FI (2 replies)
  13. what fuel pump will be sufficient? (5 replies)
  14. Electric pumps and fuel tanks for camaro's (13 replies)
  15. What to use for fuel line (0 replies)
  16. Fuel Injected vs. Carburetor? (4 replies)
  17. fuel injection tank (7 replies)
  18. ? About aluminum tubing and FI pressure (9 replies)
  19. F.I. Opinon (9 replies)
  20. 625HP Big Block - EFI Recommendation? (7 replies)
  21. lt1/t56 swap in an 81 malibu?? (13 replies)
  22. BBC Oval Port EFI Conversion, Good Start?? (0 replies)
  23. ? About Fuel Injector Sizing (8 replies)
  24. efi for a 500 -650 hp bbc whats out there (8 replies)
  25. Rick's tanks at the track (77 replies)
  26. stainless fuel line and beeding (14 replies)
  27. The "amcmike" Retrotek Powerjection III thread (6 replies)
  28. EFI Throttle Body Spacer Size (3 replies)
  29. DSE narrowed tank with LS fuel pump installed, question? (1 replies)
  30. What fuel system to use with a 540 blower motor? (5 replies)
  31. Quick FPR Question (1 replies)
  32. Remote IAC motor (2 replies)
  33. rear return system questions (9 replies)
  34. Tuning trouble with a BS3... ideas? (1 replies)
  35. Complete Budget Friendly EFI - Thoughts? (13 replies)
  36. Fast ez-efi (36 replies)
  37. LS1 fuel line & pump expeirences / ?'s (2 replies)
  38. summit 42lb injectors vs Ford 42lb injectors (7 replies)
  39. zz4 fast efi tune needed (1 replies)
  40. Fuel Pump Locking Ring??? (0 replies)
  41. What fuel pressure regulator do you like? (0 replies)
  42. PRO-FLO Shutter Wheel (7 replies)
  43. MAF Sensor and cold air intake (0 replies)
  44. LS1 fuel regulator & Projection ? (2 replies)
  45. Ricks SS tank prices (9 replies)
  46. IAC Solenoid (3 replies)
  47. Another fuel line question (11 replies)
  48. 68 Camaro Fuel Line Suggestions (7 replies)
  49. FAST XFI discovery (2 replies)
  50. Which efi system for small block chevy? (11 replies)
  51. 600HP with a TPI 383? (5 replies)
  52. F -body EFI tanks with sump! (0 replies)
  53. EFi Fuel pump, in-tank or external? (3 replies)
  54. Accel Thruster DFI - Narrow vs Wide O2 (7 replies)
  55. Aeromotive fuel filters: how to tell them apart? (11 replies)
  56. Whats a good price for an ACCEL Gen Vii (77022) DFI system? (2 replies)
  57. Pro Flo and Data Acquisition (6 replies)
  58. Fuel delivery questions... (4 replies)
  59. TPI Runner Dents (5 replies)
  60. Pressure Fluctuations (2 replies)
  61. wiring the 4DI blues (1 replies)
  62. Bung placement for FI Regulator return line on stainless tank. (1 replies)
  63. Where can I find a set of 8 Noid lights? (13 replies)
  64. ACCELL GEN 8 vs BS3 (22 replies)
  65. fuel pressure problem (17 replies)
  66. What to do with leftover ports on the gas tank??? (9 replies)
  67. Thoughts on Holley ProJection system? (1 replies)
  68. Setting Fuel Pressure (10 replies)
  69. Mega Squirt fuel injection who runs it and how do you like it? (7 replies)
  70. Pontiac 455 EFI inatake manifolds (17 replies)
  71. Changing injectors (3 replies)
  72. Which DFI to use? (7 replies)
  73. Need FI advice - ZZ502 (3 replies)
  74. can i use a stock tpi chip? (0 replies)
  75. has anyone gotten into bins and chip burning? (5 replies)
  76. any body ever heard of or used this system? (13 replies)
  77. Spectra Fuel Tanks.... (209 replies)
  78. Modified Lt1 intake? (3 replies)
  79. Ford Mustang TB on TPI/ LT1 (3 replies)
  80. what throttle bodies for twin set up??? (3 replies)
  81. Fuel pump ratings (0 replies)
  82. How should I feed my Lq9? (1 replies)
  83. blowing boost through a 4500 tb (0 replies)
  84. Priming EFI Pump before first start - no pressure (10 replies)
  85. Which throttle body to use? (6 replies)
  86. carbon fiber cold air intake (1 replies)
  87. Accel DFI 6.0 Sequential (5 replies)
  88. Which is cheaper? (5 replies)
  89. OBDII port and tuning cable information needed (5 replies)
  90. manifold question? (3 replies)
  91. Accel DFI tuner in PA/NJ (10 replies)
  92. Pics & Video of my problems with Edelbrock Closed Loop Function (12 replies)
  93. CFI to single TBI (0 replies)
  94. Diy Cold Air Intake? (5 replies)
  95. Accel DFI wiring - will not start (5 replies)
  96. Fuel Lines - 900 HP - What to use from tank? (5 replies)
  97. TPS Eratic (3 replies)
  98. Edelbrock Pro-flo 2 for b.b.c. (7 replies)
  99. Parallel vs. dead head (46 replies)
  100. Fuel injected 572 problems (4 replies)
  101. Belt Driven Fuel Pump (4 replies)
  102. Ramjet frustration (8 replies)
  103. Help with FAST XFI Startup (6 replies)
  104. HELP! Racepak (IQ3) to MEFI 4B Interface (3 replies)
  105. AN fittings for walbro external fuel pump (6 replies)
  106. Edelbrock 1st Gen Pro-Flow & LC-1 Wideband Integration (0 replies)
  107. EFI questions need advice (10 replies)
  108. Trying to use a factory sender in a modified stock tank...will it work. Pics (6 replies)
  109. Routing LT1 coolant/steam lines from back of heads? (23 replies)
  110. Edelbrock mpfi (2 replies)
  111. 502 RamJet issues. Please help!!! (9 replies)
  112. New Steel Tank (Pics), Should I coat or paint it? (3 replies)
  113. electromotive tec3 (4 replies)
  114. LT1 Idle problem solved.... (4 replies)
  115. Pre pump surge tank (1 replies)
  116. Fuel System: New to AN. (Help!) (15 replies)
  117. what sender and float should I use? (4 replies)
  118. Fuel Line (0 replies)
  119. how to get wiring into fuel tank? (2 replies)
  120. walbro fuel pump source (2 replies)
  121. Map sensors. Does the connector change depending on the BAR? (7 replies)
  122. Ls1 Tank for 1st gen question (7 replies)
  123. RamJet 502... stumbling (5 replies)
  124. A1000, stock fuel tank w/ baffling okay? (4 replies)
  125. F.A.S.T. system w/erratic idle-wtf? (0 replies)
  126. Dumb question - AN to tube adapter fittings (10 replies)
  127. Fuel pump PSI (2 replies)
  128. Thoughts on my Fuel Re Plumb (1 replies)
  129. LS1 in 68 Camaro have fuel pump question (3 replies)
  130. Is it typical for fuel pumps to whine when they suck in a little air? (4 replies)
  131. Holley Pro-Jection MPI (2 replies)
  132. whats going on here... EFI with return line (2 replies)
  133. Newb EFI? (0 replies)
  134. Holley Commander 950 (3 replies)
  135. StealthRam Injector Replacements (1 replies)
  136. Fuel Injector Question (5 replies)
  137. CAI for my driver (1 replies)
  138. can't get TPI engine fired (6 replies)
  139. EFI hose information (0 replies)
  140. 86 305 tpi (3 replies)
  141. what went wrong? (6 replies)
  142. Lean tip-in bog with Accel DFI (9 replies)
  143. BigStuff3 Crank Reference angle problem (0 replies)
  144. turbo and TBI fuel system (4 replies)
  145. Accel DFI Error when connecting to ECM (18 replies)
  146. TPI question (4 replies)
  147. Efi 540 (11 replies)
  148. II Much cold start: an update (16 replies)
  149. What kind of fuel pressure regulator? (4 replies)
  150. lt1 engine problems! (21 replies)
  151. Aftermarket ECM (3 replies)
  152. Another fuel tank vent question (22 replies)
  153. Fuel tank venting (2 replies)
  154. Help with Holley Stealth Ram and intake filter (5 replies)
  155. OEM prefilter Walbro pump...do i need another filter (6 replies)
  156. AF ration vs. HEGO voltage (2 replies)
  157. What regulator and filter with ricks tank ? (0 replies)
  158. Professional Products FI (4 replies)
  159. Russell braided SS fuel line failure (40 replies)
  160. in tank efi pump conversion kit (1 replies)
  161. MAP sensor location (8 replies)
  162. BS3 and a sbf (0 replies)
  163. Where to find a good selection of 4" intake pieces? (7 replies)
  164. Intake manifold options for a big inch small block Chevy (16 replies)
  165. What type of FI system to use? (3 replies)
  166. Is it worth it? (5 replies)
  167. Anyone paint or shrink wrap their fuel injectors to a different color??? (1 replies)
  168. camaro keeps dying (3 replies)
  169. what hi pressure fuel line do you use? (10 replies)
  170. keeping fuel tank vent: pros/cons? (4 replies)
  171. Norris Motorsports Is Now A PT Sponsor (0 replies)
  172. Fast-MSD? (1 replies)
  173. Tube AN Nuts (5 replies)
  174. Edelbrock pro flo upgrades (0 replies)
  175. "How I Fuel Injected My Pontiac 400" (8 replies)
  176. What return style Fuel Pressure Regulator for Carb with EFI In-Tank Pump? (1 replies)
  177. TBI sizing w/ single turbo (5 replies)
  178. what aluminum to use for intake plenum (4 replies)
  179. Rick's Fuel Tank Fitment Question (1 replies)
  180. Anyone using the Tanks Inc. sump with in tank fuel pump? (16 replies)
  181. Painless setup for trans and tpi (0 replies)
  182. laguna4efi Help please with XFI can link (2 replies)
  183. Newbie to FI - Fast XFI or Something Else.... (14 replies)
  184. fuel return into the bottom of tank?? (3 replies)
  185. Low Z VS High Z injectors? (2 replies)
  186. LQ4 carb going to EFI and have some questions. (4 replies)
  187. lt1 guy's (3 replies)
  188. ECM prom identification (1 replies)
  189. Injector interchangeablitity (9 replies)
  190. lt1 question (5 replies)
  191. Could someone explain returnless systems? (37 replies)
  192. ls1 or big block aftermarket fuel injection? (4 replies)
  193. injector brand (7 replies)
  194. Anybody use this tank? (5 replies)
  195. injection advise (6 replies)
  196. Question for anyone who has ever had Holley Projection 2D or 4D (1 replies)
  197. q for you efi guys - fuel pressure spikes at idle (22 replies)
  198. Fuel injection use on a 2-stroke??? (9 replies)
  199. Efi Help ! ! ! (12 replies)
  200. Is this a prank? (4 replies)
  201. Wide band 5 wire O2's the same? (4 replies)
  202. Regulator before or after fuel injection unit (5 replies)
  203. Gas Mileage (9 replies)
  204. Had a fuel pump problem yesterday..... (7 replies)
  205. Low budget FI (16 replies)
  206. If you have a commander 950 how happy are you with it? (17 replies)
  207. leaded racing fuel and O2 sensors. (5 replies)
  208. Why does this oxygen sensor cost so much? (11 replies)
  209. edelbrock proflo twin turbo? (82 replies)
  210. Fuel sump issue (2 replies)
  211. EFI fuel line question. What did you use? (1 replies)
  212. Aftermarket throttle bodies (5 replies)
  213. LTI intake w/ Vortec heads (21 replies)
  214. Is vss needed for obd1 l99/lt1 (9 replies)
  215. Fuel system parts selection (0 replies)
  216. Multi Point Tank Pickups - Walbro / Holley? (4 replies)
  217. efi for 502 67 chevelle ss stock hood (0 replies)
  218. Non Oem Efi Questions (11 replies)
  219. Tuning question egt temps? (3 replies)
  220. Sequential Vs. Batch - Idle Quality (5 replies)
  221. Butler Peformance FI for Pontiacs (4 replies)
  222. what line size???? (16 replies)
  223. Russell Full Flow AN hose ends (2 replies)
  224. Fuel return line ideas for '67 camaro (5 replies)
  225. Did I Do This Right? Pics (21 replies)
  226. MEFI4B Programing (4 replies)
  227. OBD II Scan Tools (16 replies)
  228. Does anyone make a direct injection kit for anything? (36 replies)
  229. Need fitting suggestions (16 replies)
  230. ever seen dribbling TBI injectors : (2 replies)
  231. What kind of Fuel cell are you using (7 replies)
  232. 2gen fuel tank (9 replies)
  233. BDS EFI anyone? (3 replies)
  234. efi on vortec motor (3 replies)
  235. GM SB2 heads & fuel injection, anyone running it? (12 replies)
  236. LT1 intake swap (6 replies)
  237. EFI Puzzler -- higher pressure, leaner burn (22 replies)
  238. Injector flow rating chart? (2 replies)
  239. Acell DFI ignition set up help (9 replies)
  240. Custom Aluminum Fuel injection Gas Tank (6 replies)
  241. Edelbrock LT1 intake? (2 replies)
  242. Ported LT1 heads VS LT4 heads (4 replies)
  243. Eliminator in 1st gen with LT1 (6 replies)
  244. whos running procharger and A1000 pump (12 replies)
  245. fuel pump help?!?! (2 replies)
  246. Fuel Cooler (13 replies)
  247. LT1 cam (16 replies)
  248. VEMS EFI System (1 replies)
  249. 80's era L98 tpi (12 replies)
  250. Fuel injection & vaccuum canisters? (9 replies)
