View Full Version : Custom Aluminum Fuel injection Gas Tank
nc69rs
12-07-2007, 01:27 PM
I have swapped a LS2 motor in my 69 camaro and when looking for a tank I found a guy locally that built one for me. I thought I would share the info. It is a custom built tank built to factory dimensions with a sump added for the pump to sit in. It is fully baffled and fit in the stock location using the stock straps. I ordered the Tanks Inc walbro pump and a sending unit for the gauge and took them to him. I couldn't be happier with his work and the look and fit of the tank. A tank contoured like mine with all the angles cost around $500. He will need your stock tank or a detailed drawing with measurments along with the pump you want to use or he can supply a GM pump. I will add a few pictures of my tank.His main business is building aluminum radiators. Contact info: Tapp Inc. Located in Sophia, NC #336-861-9284 http://s271.photobucket.com/albums/jj125/nc69rs/
Project69
12-07-2007, 02:47 PM
Holy crap that thing is titties!!!!!
130fe
12-07-2007, 05:09 PM
Just curious, are you are going to have enough clearance between the sending unit and the trunk pan when it is installed?
nc69rs
12-07-2007, 09:35 PM
Luckily it cleared ok! But I would have it recessed if I did it again.
syborg tt
12-09-2007, 07:05 PM
now that's a nice gas tank
Rick Dorion
12-12-2007, 09:19 AM
Nice! For other 69's I wonder if he had all the info needed. Very nice alternative. Hmm.
Vettebob1
12-31-2007, 04:56 PM
I'm going to call him and see what he would charge me to build one for my '63 Vette.
