carpedm
10-25-2008, 12:12 PM
I have the 1st gen Pro-Flo system #3550. It was all stock until recently I added an Innovate Wideband O2 sensor to assist with tuning. I had it all working correctly with the Innovate sending the wideband AFR to the wideband guage and then the narrow band signal simulation being sent to the Edelbrock ECU. This worked for about 1 week with the Edelbrock system recognizing the simulated narrow band signal just fine. I turned off the closed loop function to fine tune the driveability problems I was having as per the instructions, but when I went to turn back on the closed loop function the Edelbrock Controller rich/green/amber light is not working correctly nor will it go into closed loop mode. Here are some pics & video of what it is doing..
Here is a pic of a simplistic narrow band setup that programed for some test value voltage output from the Innovate narrow band signal wire
Here is the AFR guage
Here is the voltage output which is about perfect as I had it setup to output a constant 0.4 volts for anything leaner than 14.3 AFR as per the 1st pic.
So all appears good with the output signal from the Innovate simulated narrow band signal and the voltage output is within the operating specs (0.35V to 1.1V) as per the Edelbrock handbook.
In the next video you will see with closed loop turned "off" and the AFR switch point set at 14.3 that all appears good. The Edelbrock controller will display a red/green light correctly based on the voltage output. There is a slight response delay between the controller and the AFR guage but it does indicate correctly.
https://static1.pt-content.com/images/noimg.gif (http://s159.photobucket.com/albums/t139/69LUCFR/Vette/O2%20Sensor/?action=view¤t=O2Sensor010.flv)
In the next video its starts out with the closed loop turned off and then when I turn it "on" the red/green/amber light indicator will only flash "green"...no other color. When I turn the closed loop "off" the red/green light will come back on and switch like it should based on the voltage output.
https://static1.pt-content.com/images/noimg.gif (http://s159.photobucket.com/albums/t139/69LUCFR/Vette/O2%20Sensor/?action=view¤t=O2Sensor011.flv)
It is like the Edelbrock rich/lean function does not want to work when the closed loop is turned "on". I do not get an "amber/yellow" light at all which before I use to get this yellow light between the red/green flashes. I do not get an error message from the Edelbrock controller saying the O2 sensor is bad and according to the tests/check procedure & Innovate indicator light my wideband O2 sensor is working just fine. So I am thinking that I may have fried my Edelbrock ECU as at 1 time I mistakenly programmed the wideband output to go to the Edelbrock ECU so I was sending about 5V signal vs. a max of 1.1V that traditionally would have been recieved to the ECU.
Lastly...when I have closed loop turned off and disconnect the narrow band signal wire to the Edelbrock ECU leaving everything else hooked up believe it or not the light will flash green/red somehow and when I turn closed loop on it will only flash green...similar to what its doing above but this time the signal wire is completely cut/disconnected and I don't get any error messages on the Edelbrock controller. If I disconnect the entire O2 harness/connector the light is not lighted (its completely off).
Any help is much appreciated & thanks for the time to read & view the videos.
