69camarokid
11-04-2007, 08:26 PM
so im onstalling an LT1/t56 setup into my 69 camaro and im of course goin to need to run a return fuel line and a higher pressure fuel pump.
can anyone give me a good idea of what fuel pump to run and where i can get one... thanks guys!
DeltaT
11-05-2007, 02:40 PM
For that setup a Walbro should work fine, but I don't know the P/N. I think Summit sells them. Look for something in the 180-220gph area. For plumbing, and knowing how hot rodders are never happy with their power level (right?), I'd spec the pump feed line large, then send the fuel up to the engine compartment in like a -8 line, then use a -6 from there. That way you'll be over-built and need only change the front line when you expand later with those twin turbos you are eyeing! -6 on the return should be fine.
Jim
69camarokid
11-05-2007, 10:14 PM
hahaha truer words have neer been spoken... more power is never enough haha
but thanks very much for the help as i have no idea when i comes to fuel injection
