View Full Version : Map sensors. Does the connector change depending on the BAR?
Larry Callahan
08-26-2008, 07:32 PM
Does the style of the weatherpack connector change if you go from a 1 bar to a 2 or 3 bar sensor? I had a one bar, bought a 2 bar and the connector wont't fit. Is that right? If so where is a good place to order a new connector?
The picture below is not mine but I have two that look just like it.
Larry Callahan
08-26-2008, 07:48 PM
Doh! I think I just found my answer. Some guy on a site posted Delphi blueprints of the sensors. I see they are different. I still need to find a connector.
camcojb
08-26-2008, 08:08 PM
yes, they're different. I've always modded mine by cutting a slot where needed so the 1 bar work on the 2 bar.
Jofy
MrForce
08-27-2008, 12:38 PM
Typically the one bar connectors are green and the 2 and 3 bar connectors are orange. The pins and pinout are the same and cutting a slot is the quickest solution.
Larry Callahan
08-27-2008, 03:49 PM
Hmm, I hope Frank does not cut himself with a razor blade. LOL!
DeltaT
08-29-2008, 12:48 PM
eficonnection.com sells a 2-bar (orange) wired connector with pigtail for $11.50.
Jim
Larry Callahan
08-29-2008, 01:18 PM
Thanks, I think I will order one.
DeltaT
08-30-2008, 03:22 PM
If you do, and you don't already have a WeatherPak pin removal tool, the barrel kind, you might spend an extra $5 or so to get this tool - it saves a lot of time.
Jim
