GetMore
03-05-2009, 10:13 PM
I am looking for a regualtor for an Edelbrock setup. I'm going to be using their manifold and rails (p/n 3936 on the rails, IIRC).
What would you use as a regulator?
I'm running naturally aspirated, so I don't need it to be boost referenced, though I will have it vacuum referenced. Pressure will probably be around 48 psi, though I may change injectors somewhere along the line and run 58 or so.
TIA
TIA
