mgcbus65
01-26-2008, 12:22 PM
Hi, How has everyone run their fuel lines for a lt1/ l99 retrofit or any other high pressure system? I am planning on using a tank and sending unit from a 94 buick roadmaster in a 64 chevelle 2dr wagon with the l/99 engine from a caprice and have to decide on how to run the lines and connections. Suggestions? Thanks, George
Samckitt
01-26-2008, 12:48 PM
I used a Buick Grand National sending unit (Direct replacement in my Monte), and replaced the rubber lines near the tank with high pressure rubber pieces made for fuel injection. Then use 2 worm/band clamps on each connection & have had no problems. I had a -8 AN fitting welded onto the LT1 fuel rail & used An fittings & braided line up near the motor for looks.
