View Full Version : Suspension
- DSE subframe is here (7 replies)
- Roll couple, Roll axis?? (16 replies)
- Quick Change Rear... (0 replies)
- 71 Cougar Ford 9" To 69 Camaro Conversion (3 replies)
- comments/suggestions on my Malibu wagon's setup (3 replies)
- Rear sway bar or Factory "traction bars"??? (2 replies)
- Questions on GM A-Body suspension/chassis setup (17 replies)
- Moog parts....what gives? (5 replies)
- Strange Coil over shocks (1 replies)
- looking for guidance. (3 replies)
- Need help with a Plymouth (20 replies)
- '03 crown vic steering rack upgrade (1 replies)
- where to buy solid body bushings? (8 replies)
- springs rec's and coil-over question (0 replies)
- Spherical eye sway bar end links? (5 replies)
- Basic Sway Bar Question (newb) (11 replies)
- Hotchkis Suspension best place to buy??? (7 replies)
- Performance Trends Help? (2 replies)
- Torque arm question (2 replies)
- What shocks??? (2 replies)
- Air Ride suspension (11 replies)
- G-body w/ATS spindles? (1 replies)
- Choosing a ride height? (5 replies)
- changing the steering rack (0 replies)
- Question on what shocks to get with the hotchkis springs... (4 replies)
- ATS Spindles (1 replies)
- Need some info on the Lincoln mark VIII rear end! (3 replies)
- Ball joint exstenders. No not those ones.. Suspension guys comment please (19 replies)
- 3 Link, Stop me before it's too late... (34 replies)
- Global West sfc, NO instructions! (2 replies)
- Did I get the right hotchkis springs off ebay?!?! (6 replies)
- Suspension suggestion wanted....Please (4 replies)
- Tie rod options (0 replies)
- Frt End Chassis Stiffeners (2 replies)
- Best Suspension for 1st Gen Camaro (21 replies)
- Help please!! (7 replies)
- Disc upgrades who make some??? (1 replies)
- rear suspension (4 replies)
- Can Shortened F Body Control Arms Work? (6 replies)
- Chp (12 replies)
- Frame side panhard bar mount (1 replies)
- Woodward brand power steering reservoir? (3 replies)
- Steel C5 front control arms (7 replies)
- Do you have a 73-77 A-body? If so, Hotchkis need to borrow your car. (3 replies)
- Straight axle, curved road? (19 replies)
- Dimensions of lower/upper C5 front control arms? (2 replies)
- AGR Steering box noise? (1 replies)
- DSE Speed Kit 1-3 (1 replies)
- Decifering PT reports (2 replies)
- Clean Sheet Front Suspension For "G" Body (6 replies)
- different steering pump (1 replies)
- How do I fix this type of steering slop? (0 replies)
- Animated performance trends. (3 replies)
- shocks (2 replies)
- power steering box what one? (4 replies)
- ATs (2 replies)
- How did you mount them? Air-Ride Dilema (4 replies)
- shorten driveshaft (1 replies)
- Removable steering rod on GM A-body (4 replies)
- Speedway Upper control arms (1 replies)
- Tubular A arms that lower? (12 replies)
- Any install tips for Stage 2 kit from SC&C? (10 replies)
- A body - G body suspension compatability (2 replies)
- ATS Spindle tie rod problems?? (34 replies)
- Lowering question - 95 Park Avenue (1 replies)
- Got new Moser Rearend Today (9 replies)
- C4 Irs (5 replies)
- DSE kit mini-tub kit question (0 replies)
- Anyone see the arcticle on rack conversions in HOT ROD? (4 replies)
- Go ahead... tell me how dumb I am... (11 replies)
- Could I drag race with ATS spindles? (11 replies)
- ALIGNMENT SPECS FOR 2nd gen (20 replies)
- Help on Lowering my Torino (4 replies)
- Suspension Dimensions (14 replies)
- "El.plating" (9 replies)
- subframe bolts (2 replies)
- sitting high (3 replies)
- Anyone use 'GM Spindle Length Spacer'? (3 replies)
- Hotchkis A-arms (5 replies)
- Air ride on a 2nd gen (9 replies)
- Chevy II Leaf springs help (4 replies)
- leaf spring rear suspension design books (7 replies)
- how low ? (15 replies)
- Leaf Spring (Yes, you read right) Question... (10 replies)
- difference in 64 and 65 GTO frames (11 replies)
- Global West (3 replies)
- What Shock should i Use...? (9 replies)
- paging silver69camaro (1 replies)
- Pro shock (6 replies)
- A-BODY frame boxing is a waste of time. (12 replies)
- Who is correct (5 replies)
- Need AFX spindle and steering arm help (2 replies)
- Power Steering question... (1 replies)
- Alignment/box questions (10 replies)
- to hiem or not to hiem????? what would u use??? (6 replies)
- IRS suspension. (3 replies)
- Watts Link (1 replies)
- Custom Rag joint (4 replies)
- Lowering suspension question... (7 replies)
- Autofab Racecars - Street Rod Ladder Bars (18 replies)
- Steering box and pump recommendations? (0 replies)
- Opinions On Set Up Pls (6 replies)
- Looking for rear mini tubs for g body (5 replies)
- Camaro and Mustang full chassis (5 replies)
- Manual steering box help (39 replies)
- Chevelle Spindle Question (2 replies)
- Rear Leaf Spring Perch Question (2 replies)
- Power to manual steering box second gen (7 replies)
- suspension geometry relocation (8 replies)
- Sources for tubing (23 replies)
- What front end kit?????? (10 replies)
- Roundy round spring questions (4 replies)
- Suspension balance - coils with air - do they work together? (13 replies)
- Just received my parts from SC & C! (13 replies)
- hotchkis swaybars (7 replies)
- Slidealinks (0 replies)
- Paging silver69camaro (2 replies)
- Suspension design and theory (0 replies)
- Hotchkis 2" lowered Springs hitting... (3 replies)
- wide-track Camaro suspension ????? (8 replies)
- Hotchkis front spring question (0 replies)
- Performance Trends Users (3 replies)
- GTO frame Help (3 replies)
- Another Suspension Question (2 replies)
- Ready To ship!!!! (1 replies)
- Pagging Craig Morrison - New AME First Gen Sub (5 replies)
- New guy with first question. Tubular control arms? (1 replies)
- Airride on a 1st gen Camaro YES or NO (27 replies)
- Why run a front sway bar? (9 replies)
- Knurled cross-shaft a-arm bolt (6 replies)
- Any other suspension shops other then DSE, global west?(need susp. help bad) (2 replies)
- Suspension Help (13 replies)
- Front sub-frame to Firewall bracing (43 replies)
- Which lowering springs? (0 replies)
- rear sway bar (0 replies)
- Tall lower ball joints ??? (5 replies)
- G-machine (6 replies)
- More A-body suspension questions (4 replies)
- air bar any body run one? (1 replies)
- Cal Trac or Slide a link (8 replies)
- Mixing Global West UCAs with DSE LCAs (7 replies)
- PS problem... (3 replies)
- 4 Link with tailpipes? (4 replies)
- chris alstons Gbar, heidts 4 link, DSE Quadra link (6 replies)
- Iroc/GTA "Z" box on 1st gen Camaro (11 replies)
- Will Fatman G force spindles work? (0 replies)
- What kind of "flex" do subframe connectors prevent? (7 replies)
- front sub frame who's and why's (13 replies)
- If you have a 67-68 camaro with AFX spindles, please help! (5 replies)
- Anyone know what DSE leaf spring rates are? (4 replies)
- suspension freaks (3 replies)
- Cutting front coils...1 coil==2"??? (3 replies)
- 66 Chevelle (10 replies)
- actual ride height of DSE 2" or 3" rear leafs on 69 Camaro (7 replies)
- 1LE Rear Control Arm Bushings - G-Body Guys Come Out (2 replies)
- Anybody see the new Subframe from Speed-Tech? (4 replies)
- rear suspension/wheels/tires is bigger better? (1 replies)
- g-machine prototype mustang spindles (12 replies)
- aftermarket camaro steering arms (6 replies)
- PS plumbing question..low side (1 replies)
- Confused about AGR Steering box (6 replies)
- Do aluminum control arms help a lot? (0 replies)
- ? about sfc's (8 replies)
- Front geometry quiz. (15 replies)
- Nova Suspension Advice (0 replies)
- How do I go lower? (0 replies)
- Global West's Category 5 leaf spring??? (5 replies)
- afco ball joint? (11 replies)
- G body rear suspension (8 replies)
- GM A-body guys and suspension guru's come on in! (40 replies)
- Stock & Hotchkis TVS 2nd Gen Suspension Dimensions (0 replies)
- Solid front leaf spring bushings? (5 replies)
- Anyone here use a steering box brace? (3 replies)
- Art Morrison's new frame? (29 replies)
- C4 IRS in 2nd gen Camaro???? (5 replies)
- What first? (4 replies)
- controller arms (3 replies)
- suspension work in S.F. area (7 replies)
- Which 4-link to buy?? (6 replies)
- DSE Quadralink (0 replies)
- for handling, leaf springs, 3 link, 4 link??? (30 replies)
- Suspension shims? (5 replies)
- angle of trailing arms? (9 replies)
- 1970 GTO lower 4 Link Arms, Official G-Machine setup! (9 replies)
- Reinforcing stock front LCAs. (24 replies)
- Leveling a Uni-Body mustang question. (2 replies)
- Any pics of chevelle with 1 inch drop (0 replies)
- 1955/56 Shoebox Suspension Upgrades (12 replies)
- Why did GM go to front steer in the mid 70's? (3 replies)
- Rear spring install on a 1st Gen (3 replies)
- Rear Leaf Springs Clips on a First Gen (1 replies)
- My new Lateral Dynamics 3-link (pics inside) (23 replies)
- Alignment specs - 68 Camaro. What I can do without GS mod (8 replies)
- Help me figure this one out! (4 replies)
- Shocks (5 replies)
- Caster gain (8 replies)
- Is it typical for slop to develop in 68 and newer collapsible steering columns? (2 replies)
- Can I tighten wheel bearing castle nuts more after break in? (4 replies)
- My front end is so light now I have suspension problems. (6 replies)
- short steering arms ; camaro (4 replies)
- Notched control arm (7 replies)
- muscle car TV front steering (11 replies)
- used trailing arms (3 replies)
- Hotckis vs Eibach (4 replies)
- Hydroboost Fluid Question (7 replies)
- Global West Billet Offset Cross Shafts (3 replies)
- Drop Spindle Dilemma (11 replies)
- rack and pinion bump steer (10 replies)
- Drop spindles or lowering springs on my 69 camaro (3 replies)
- QA1 coil over (2 replies)
- custom steering arms (8 replies)
- What springs do i go with with out goin to low? (10 replies)
- Dropping an 86 S-10 Blazer 4x4? (10 replies)
- Need some opinions on a 68 camaro suspension (7 replies)
- PLumbing for airride? (5 replies)
- My ideas for a 1st/ 2nd gen Camaro rear... (7 replies)
- my formula lsx (3 replies)
- Shock reloction questions... (2 replies)
- 825 power steering box. (0 replies)
- '66 GM A-body rear coilover conversion (2 replies)
- Mini tub question. (1 replies)
- ball joints removing spindle (10 replies)
- Custom chassis design I am working on (4 replies)
- QuadraLink Rear Sway Bar? (8 replies)
- QA1 sketch (2 replies)
- New Chassisworks Subframe?! (7 replies)
- J-nuts for the front leaf spring bracket-Camaro and Nova (9 replies)
- Whats up with HOTCHKIS a-body lower control arms? (0 replies)
- Subframe Patch Plates (9 replies)
- Thinking about Air suspension for my 55 - Any advice ? (17 replies)
- Car Is Uneven (5 replies)
- size castle nuts for Camaro pitman and idler? (5 replies)
- sway bar sizing (7 replies)
- dimensions of spindles (16 replies)
- With a mini tub, how come only move in the rear? (4 replies)
- Anyone with PST suspension experience? (5 replies)
- non PT, but how do you replace the front axle seals for a 2001 Suburban? (5 replies)
- subframe bushings, squished?? (10 replies)
- How much more clearance do I get from a mini tub? (1 replies)
- global west (27 replies)
- manual steering box questions (2 replies)
- suspension info (1 replies)
- New Eibachs in - Need Advice on Raising the Rear (0 replies)
- Your thoughts on BMR Tubular A-Arms? (0 replies)
- your thoughts on this watts link setup... (12 replies)
- 1957 Cheyy pickup suspension (0 replies)
- 66 biscayne front suspension (1 replies)
- Aftermarket Steering Column ?'s (0 replies)
- B-body spindle on early Chevelle?? (8 replies)
- nice A arms (6 replies)
