SHANE 73Z
02-13-2007, 04:26 PM
Hey guys,
Just looking for a little experience here. I am setting up my PS system and have been overwelmed by the information that I have collected so far.
The system will include a compact pump, remote reservoir & cooler. I already have a proper teflon lined high pressure hose. -10 for reservoir to pump, -6 for the rest.
The vendors I have talked with have given me conflicting information regarding plumbing the low side. I wanted to run Push-lok hose for low side, but one vendor I talked with warned against it, reporting that the hose didnt have sufficient vacuum ratings for the -10 hose, yet he also stressed the fact that the reservoir should be mounted higher than the pump allowing a gravity feed. I can see a small vacuum being created by the pump, but enough to pull a -10 hose shut?
Will the Push-Lok be OK? Anyone have any experience with this?
I know it may be brought up, but I have tried to avoid braided stainless lines when not needed as it appears to be overkill for my needs. The only ones presently on the car are the brake flex lines.
Thanks in advance,
Shane
Thanks in advance,
Shane
