Chad-1stGen
02-04-2007, 04:58 PM
Hey All,
I have all my suspension parts installed now and when I get my T56 back from the rebuilder I plan on getting an alignment. I've been reading this site for the past few hours and while there is lots of good advice on specs and a lot of it consistent (good sign for me) I'm not clear on what specs are acheivable with stock arms? As I have my eyes on the AFX spindles as a future upgrade I don't realy wan't to do the GS mod for now.
Currently: Stock subframe, stock A-Arms, Hotckis front and rear springs (2" drop), Hotckis revalved Bilstiens, Hotckis 1 1/8" anti-sway bar.
Intended use of the car is 90% street and some track days once all the bugs are worked out of the car. Plenty of street driving on the freeway so high speed stability is a concern.
I've also read of some poeple having to supply their own shims? Is that normal?
Ok so I stole the following specs from a chicane post:
As per Global west:
Driver side / Passenger side
Caster 2 degree’s positive / Caster 2 ½ degree’s positive
Camber ½ to ¾ degree negative / Camber ½ to ¾ degree negative
Set toe to toe-in (3/32 total) / Set toe to toe-in (3/32 total)
As per DSE:
Caster 5 degree's positive / Caster 5 degree's positive
Camber ½ degree negative / Camber ½ degree negative
Set toe to toe-in (1/16 total) / Set toe to toe-in (1/16 total) 1/8 overall
As per Guldstrand:
Caster 3 degree's positive / Caster 3 ½ degree's positive
Camber 3/4 to 1 degree negative / Camber 3/4 to 1 degree negative
Also per David Pozzi's page:
Guldstrand recommends the following specs for a "touring car":
Caster: 3 - 4 degrees positive (+) PS = more, manual steer less.
Camber: 1/4 to 1/2 degrees negative (-)
With upper a-arm relocation Camber: 0 degrees
Toe-in: 0 - 1/8 inch Guldstrand recomends for racing:
(assumes "Guldstrand mod" is done)
Caster 3 to 4 1/8 deg pos
Camber 1.5 to 2 deg neg
Toe in 1/8" out to 1/8" in (I would try 1/8" out first) more neg camber = more toe out. Herb Adams recomends these alignment specs for the street:
1 degree positive caster ( I would use 3.5 degrees if PS)
1 degree negative camber.
1/16" toe in Stock factory alignment specs:
Caster +1/2 deg
Camber + 1/4 to 1/2 deg
Toe-in 1/8" to 1/4" (Radial tires need less toe-in, use 1/8" or less for them) David has recommend his specs before but I wanted to make sure I got the right ones lol.
I'm thinking from reading other posts that if I can get 3* positive caster out of the unmodded geomtry I'm doing good? Is there a limitation on the ability to get a full 1* negative camber? Finally 1/16 toe in sounds like the way to go?
Thanks to the suspension experts for helping answer yet another alignment question.
As per Global west:
As per DSE:
As per Guldstrand:
Caster +1/2 deg
