- Elec. Speedo on 67 Camaro (0 replies)
- Warning Lamp Senders? (1 replies)
- Need wiring a CS144 alternator help (6 replies)
- Break light help! (3 replies)
- Autometer Cobra Gauges w/ LED (0 replies)
- aftermarket deck (2 replies)
- Car stays running and other wierd things (6 replies)
- morris classic turn signal/driving light (4 replies)
- Neutral safety switch (5 replies)
- 1999 Suburban Electrical & Start Problems (19 replies)
- battery cable (2 replies)
- Alt low charging (3 replies)
- Led Taillight Kit (5 replies)
- remote starter solenoid with mini starter (7 replies)
- 69 camaro wiring diagrams Free! (1 replies)
- source for American Autowire (14 replies)
- Trouble shooting the horn relay (5 replies)
- Lights wont come on now? (1 replies)
- Where to pass battery cables through firewall (8 replies)
- Winter Battery Float Charger Question (3 replies)
- Marquez Taillight question (2 replies)
- My car died (8 replies)
- Wiring harness (1 replies)
- Another halogen headlamp conversion question (2 replies)
- 1st Gen tail lamp housing. (0 replies)
- electric life shaved handle install (0 replies)
- Turn signal contact problems (4 replies)
- Power Window Switch's In 68-69 Camaro Console (5 replies)
- Recommended OBDII code reader? (9 replies)
- Ignition tick (1 replies)
- Time for new wiring harness. (22 replies)
- msd location help (9 replies)
- Non PT Car Audio question for an Audio guru (11 replies)
- Battery Cables? (1 replies)
- bulbs similar to T3s?.. BUT! (4 replies)
- Multipin connectors for gauge harnesses (4 replies)
- Pleasent surprise from Stewart Warner (20 replies)
- Original 69 gauges with LSx (1 replies)
- 69 camaro horn relay upgrade (2 replies)
- Does this sound like a bad ignition switch? (9 replies)
- 67 rs headlite doors (3 replies)
- Igntion problem (2 replies)
- Modern gauge conversion, 70-81 Firebird...Help! (10 replies)
- C5 door mirror wiring?? (6 replies)
- Injector and alternator wiring question (3 replies)
- autometer speedo / 4l80e trans (6 replies)
- Missing O2 wiring (3 replies)
- Electric temp. gauge (12 replies)
- need help with 94 Bonneville (2 replies)
- AAW Tail lights (1 replies)
- 69 Chevelle Tail lights. PLEASE HELP! (2 replies)
- thinking about installing power windows (4 replies)
- Electrical woes. (7 replies)
- Who sells power window switches? (5 replies)
- HID Sealed Beam Conversions? (16 replies)
- Dakata Digital Dash (5 replies)
- Connecting audio to 2nd battery (9 replies)
- The "best" alternator (4 replies)
- Slooow Cranking When Hot... (5 replies)
- Speakers in Convertible 69 Camaro (2 replies)
- No spark in Vortec 454 (6 replies)
- Daily driver electrical/starting problem (3 replies)
- Stereo setup for my 72 Nova (6 replies)
- Trunk-mounted battery question (4 replies)
- LED Animation (0 replies)
- CS 130 wiring? (2 replies)
- price for painless install? (5 replies)
- Speedo mis-calibration (1 replies)
- Headlights on the Overhaul'n 69 Mustang (4 replies)
- Reverse Lights For Truck (2 replies)
- 99 t/a sub woofers at rear seats blown (0 replies)
- Experience with this kit (9 replies)
- Running amp and speaker wires (6 replies)
- Packard Electric connector tools (6 replies)
- Q for those of you running subwoofers in old iron... (3 replies)
- H4 headlights for 68 Camaro. Where/what to get? (12 replies)
- New alternator mount - dissimilar metals (9 replies)
- One Wire Alternator and my 67 Camaro (5 replies)
- Urgent! Leaving for Carlisle in AM! (2 replies)
- Viper T56 Trans Wiring Schematic (1 replies)
- Voltage drop tests (0 replies)
- Looking for Cheap LED tail lights? (7 replies)
- Autometer TKO install (0 replies)
- i found the problem!!!, i hope? (6 replies)
- im going crazy with the electrical (22 replies)
- Sequential Taillights (3 replies)
- New alternator (1 replies)
- Got an Autometer question (0 replies)
- Alarm install tips ??? (0 replies)
- starter still cranks while key is off (1 replies)
- L.E.D. Taillights (11 replies)
- fuel gauge wiring 67/99 camaro with fuel cell (1 replies)
- LT1 Alternator alternatives (8 replies)
- Who else besides Painless makes wire harness kits? (3 replies)
- LT1 wiring harness (4 replies)
- Remote Starter Solenoid (6 replies)
- New Alt Wiring (8 replies)
- Autometer Won't Calibrate (19 replies)
- Interior Lights Are Staying On!! (4 replies)
- DC Contoller (0 replies)
- DC Contoller (4 replies)
- starter woes? (3 replies)
- 69 Firebird Tail Light Bucket Needed (7 replies)
- Odyssey battery (4 replies)
- sending units going bad? (12 replies)
- ECU and Ignition box mounting........ (2 replies)
- LED Shift Light (1 replies)
- Turn signal blowing fuse (2 replies)
- gen light prob (0 replies)
- LED turn signals for my scooter (4 replies)
- Need help with 4th gen headlight switch in 69 (0 replies)
- looking for wire loom (3 replies)
- Bright Filament Wire? (6 replies)
- Tips on wiring up the '68 Camaro (7 replies)
- EZWiring harness (10 replies)
- Generator light on; only getting 13V. (0 replies)
- Horn wiring problems (4 replies)
- AAW HiWay 22 question: fuel pump always hot? (1 replies)
- Master disconnect switch (9 replies)
- Need tach help (0 replies)
- shaved Door handle kit (1 replies)
- Need some help with some electrical problems... (2 replies)
- Alternator Wiring (4 replies)
- new camaro enclosure (1 replies)
- Help with horns (5 replies)
- 4th gen wiper moter wiring (5 replies)
- No ignition switch when warm ??? (14 replies)
- question on door solenoids (1 replies)
- Truck issues... (0 replies)
- Tach mounting ideas? (0 replies)
- installing wires - neutral safety switch (1 replies)
- Fuel pump mounting ideas for '67-68 F-Body. (10 replies)
- Ls1 swap wiring issues... (1 replies)
- Key will not kill the engine (10 replies)
- Battery is dying (7 replies)
- MARK VIII not Starting (3 replies)
- GTO/Corvette Instrument Cluster (5 replies)
- High rpm alternator (22 replies)
- anyone know of cool flush mount led tailights (7 replies)
- 92-98 Buick power mirror wiring/switch (5 replies)
- Wires & Pliers Website Updated!! (3 replies)
- Starter recommendation (8 replies)
- Where to buy electrical connectors? (7 replies)
- Got some ECU problemo's. Need help. (14 replies)
- Temp sending unit for 1970 Camaro (2 replies)
- Alternator conversion (1 replies)
- Battery Hold Downs (2 replies)
- Battery wiring questions... (4 replies)
- MAD Electrical (14 replies)
- Mounting Coil Inside interior........ (7 replies)
- dse bright driving lights (11 replies)
- How to wire 67 Camaro factory tach (2 replies)
- 2nd gen. tach filter (0 replies)
- how to wire a inter reg alt? (3 replies)
- Who repairs tachs? (3 replies)
- LEDs for tail lights; red or white? (7 replies)
- Hidden Radio Antenna?? (14 replies)
- Question about aftermarket stuff... (3 replies)
- GM Wiper Switch wiring ? (3 replies)
- Remote door openers (4 replies)
- Which engine/light harness should I buy? (2 replies)
- Need help with ls1 swap wiring!!! (9 replies)
- )Perplexing light problem,, Lights work with no ground? (2 replies)
- Hidden windshield wiper motor (14 replies)
- For those with a trunk mount DSE kit (0 replies)
- Temp sending unit question (68 camaro) (1 replies)
- HELP! camaro will not start (4 replies)
- HELP! camaro will not start (7 replies)
- Car won't start... PLease help (18 replies)
- Battery Ground (28 replies)
- First gen MSD box location? (11 replies)
- Stand-alone knock sensor? (6 replies)
- New Autometer gauges!!! (3 replies)
- Neutral Safety Switch?? (2 replies)
- RS/SS headlights ?? (2 replies)
- M.a.d. Full Power New System (9 replies)
- Ignition Switch Problem (3 replies)
- Projector headlights for classics (8 replies)
- Rain sensor wipers (2 replies)
- How many of these LED lights can be wired together? (9 replies)
- Brain fart on relays... headlights wiring (13 replies)
- Power programmer ?'s (0 replies)
- RS headlight doors not closing (1 replies)
- autometer fuel gauge wiring in 69 camaro (9 replies)
- any one ever seen these light (19 replies)
- A little taillight problem (10 replies)
- What size wire from trunk battery to starter (8 replies)
- Stack gauge pod in a '68 Camaro (0 replies)
- Wire routing for trunk battery (8 replies)
- Harness for 67 Camaro / Firebird (7 replies)
- EMP protection just for fun (9 replies)
- Starter wiring (9 replies)
- a little help (1 replies)
- hidden electrical kill switch inside interior (14 replies)
- Push to start button? (24 replies)
- Domn parking light question (6 replies)
- 67 Camaro Charging problems,, (4 replies)
- Wire Melt Down (6 replies)
- Magic Tach (0 replies)
- Lower vallance light bulbs? (8 replies)
- Door wire loom location? (3 replies)
- 66 mustang LED taillight kit... (2 replies)
- RF Interference with EFI System (13 replies)
- Head Lights (7 replies)
- Less expensive alternatives to Electric-Life for Power windows and locks? (13 replies)
- variable blower motor speed, how to? (2 replies)
- Hei with msd? (4 replies)
- lt1 into a 65 chevelle ?? (1 replies)
- L.E.D. Install questions??? (11 replies)
- ANy feedback on RS HEadlight Conversion Kits? (29 replies)
- Rear Led Taillights - Looking for info (2 replies)
- Still having trouble (1 replies)
- How to run wires through door jamb???????? (30 replies)
- What size fuses??? (1 replies)
- Central power and ground??? (3 replies)
- power seat switches (2 replies)
- G-body Led Lights (12 replies)
- RS headlight motor conversion kit (6 replies)
- electrical suppl.ies (4 replies)
- 67 RS headlight trouble (7 replies)
- Hissing Optima (7 replies)
- Autometer D-pic Update? (2 replies)
- Can anyone share their experience with installing Electric Life Windows? (20 replies)
- electrical help please (3 replies)
- 67 Camaro Tail light wiring question (6 replies)
- Nice anti-theft idea, very simple. (0 replies)
- Wiring radiators (2 replies)
- DS&E bright driver lights question (3 replies)
- Wiring to Doors (1 replies)
- Automatic wiper control (6 replies)
- chicayne headlights... (1 replies)
- VW wiper motor (0 replies)
- GXL OR TXL wire (8 replies)
- Alternators 2 VS Me... Nothing! (15 replies)
- Mustang guys! Our 67 Mustang alternator is not working? (4 replies)
- Problem With The 58 (2 replies)
- DSE - Wiper Kit Instructions (5 replies)
- Help I got no Juice (2 replies)
- Ford Starter Solenoid as a fan relay? (3 replies)
- Mad enterprises (1 replies)
- Old 60amp to CS 180 amp conversion (5 replies)
- 4th Gen Power Seat Electrical Connections (2 replies)
- Has Anyone Tried Ron's Wiring Harnesses (14 replies)
- stranded at work! (3 replies)
- DSE wiper motor (6 replies)
- Which Optima red top would be the easiest to get a mount for? (4 replies)
- Help: 69 Camaro will not start (5 replies)
- where is the resistor pack on 2nd gen camaro? (9 replies)
- fan wiring (9 replies)
- Those of you with 98-02 F-body instruments: (1 replies)
