View Full Version : LEDs for tail lights; red or white?
Samckitt
03-13-2006, 07:54 PM
I am thinking of trying to make some LED tail lights for the Monte, I was wondering which LEDs are better to use, red ones or white ones. Of course I am using the factory red lens on the car. So either way the lens will make the light red. But will the white be too overpowering & make it look abnormal?
Scot
CAMAROBOY69
03-14-2006, 04:10 PM
If all else fails do an experiment with one of each behind the red lense material. Check it in the dark. Great question.
zbugger
03-14-2006, 04:25 PM
I swapped from a white normal bulb to a red LED bulb on my Camaro. The light changed from a pinkish light to a solid red. I say go with the red LED's. I hate pink brake lights.
Samckitt
03-14-2006, 05:16 PM
The other thing I thought of was using LEDs with a flat end instead of the round dome. This will spread out the light more instead of the dot you usually see. I don't know. On one hand I like all the individual dots & on the other hand it would be cool for the whole lens to light up without seeing the bulbs.
Scot
zbugger
03-14-2006, 05:37 PM
That's how the AAW lights illuminate. You can't see the individual LED's. I'd do it that way if I were to do it myself as well.
Samckitt
03-14-2006, 05:43 PM
Oh no! I have to figure out how to wire it so some of them light as running lights, then all of them light when the brakes or turns are lit up. And a voltage limiting resistor on every LED to drop from 12V to ~4V. Man that will be a lot of resistors.
Aye Caramba
Scot
gen3bu
03-14-2006, 05:54 PM
use the red ones. the ast bike taillight i made looked better with a red lense and red leds. plus, the red leds were brighter that the whites that i bought, and they were both rated @ 6000 mcd. that motorcycle brakelight had 242 leds when i was done.
the tail/brake lighting is easy. pm me for more details.
kevin
67 455 Bird ragtop
03-22-2006, 04:42 AM
You always should use the same color LED as the lens it will shine through. Here is a prtty good site for leds and led info. I got all the leds for my 97 GTP from here.
http://www.superbrightleds.com/
