TPI Monte SS
08-21-2006, 05:44 AM
Hey all,
Got one minor issue with the Monte. Seems that after I drive the car for a while and shut it down, when I go to restart it the starter cranks ~very~ slowly, then speeds up. Here's the specs on my electrical system -
- Approx. 2-year old Exide gel-cell battery, been totally drained once due to a bad fuel pump relay
- New reman. LT1 ministarter, installed 100 miles ago.
- 2-gage positive cable from battery to starter
- 4-gage negative cable from battery to accessory bracket bolt on the motor
- 6-gage additional ground wire added from a starter bolt to the frame
- stock ground strap is hooked from the firewall to the coil bracket on the intake
- upgraded to 10-gage wire running from S-terminal on the alternator directly to the battery.
The alternator is about 5 years old, but only has 20K on it or less. It does seem to have good cruising voltage according to the crappy stock gauge in the dash, though I haven't checked it with my voltmeter (it's locked in my classroom at work for the summer).
Where should I look, and what should I check to get this puppy to spin over consistently, even in the heat?
