View Full Version : Dakata Digital Dash
paul67
08-24-2006, 12:03 AM
Trying calibrate the speedo on my dash for the 67 camaro ,does anybody were the speedo trip button is and reset ,waited 2 day from dakota and no reply, need it as we have loads of speed cameras localy
Happyfunballs
08-24-2006, 05:12 AM
You should've received 2 buttons with your "kit". Each button has two leads on them. There is a sw1 and a sw2 on the brain. One lead goes to sw1 or 2 and the other to ground. I forget the sequence in which you need to drive/press the button, but that's how it's done.
paul67
08-24-2006, 09:12 AM
:crying: Had the unit for 5yrs been to usa loads then find this out.
Happyfunballs
08-24-2006, 11:49 AM
Hate to sound like an a$$-bag, but did you download the instruction manual from DD website (http://www.dakotadigital.com/pdf/vfd-3.pdf)? Look on page 10. Any normally open switch would work. Actually, you might be able to get away with attaching a wire to the proper sw terminal and just grounding it.
paul67
08-24-2006, 01:50 PM
So what there saying is connect a push button ,1 wire to the box and the other end to ground then press the button and do the 1 ml test run .
Happyfunballs
08-24-2006, 04:59 PM
That is correct.
